Front end diagnosis
Old May 24, 2011 | 12:02 PM
BookD's Avatar
BookD
3rd Gear
Default Front end diagnosis
Have a 2000 C5 with about 50k and began to notice a nasty steering wheel wobble at around 65mph. Wobble is steady in frequency but increasing in amplitude as speed increases past 65. Also on right hand turns there is a grinding noise from the front end. Left turns produce no noise and are firm through the corner, but on right turns the car feels very loose. Braking/acceleration through right turns makes the problem considerably worse. Recently swapped in Texas Speed LT headers which rubbed the steering column briefly...
Any thoughts? Main bearing or worse? Any help is appreciated guys, first corvette and pretty hesitant to jump in on my own intuition.
Old May 24, 2011 | 12:14 PM
redrckt97's Avatar
redrckt97
sounds like a left front wheel bearing. Have it checked out asap.
