Lowering a C5 by adjusting stock bolts
I'm looking for info on how to lower a C5 by adjusting the stock bolts. I hear this can be done and there are write-ups about it, but where? Post any known directions please!
Why is it every other time you search through the DYI section you see everything and the kitchen sink except for what you're looking for?
Kudos to BigGun
Kudos to BigGun
Doing it right
Here is the way to do it right. There are a lot of threads on doing it and most of them will have you screwing up the setup of the car.
http://forums.corvetteforum.com/1576940245-post106.html
Luckily our roads are nice here in O-town and I don't race or corner fast on the roads. And hopefully I don't wreck my "pride and joy" due to your over-steer theory. I've had 4 C5's lowered as such and never noticed this dangerous over-steer you note (not saying it does not exist).
One of the main things to keep in mind is to maintain any side to side imbalance or difference in the boltse. Hopefully, that will keep the car level and fairly evenly balanced. You should also consider an alignment to avoid premature tire wear.
I pulled the rear bolts and dropped the car onto the suspension to see the rear travel. A stock C5 is on the rear bump stop when the tread of the wheel is at most 1/4" up inside the wheel well. I haven't checked the front because that would require pulling the spring, but maybe some day I will. I expect it to have more travel than the rear but not a huge amount more. Just something to think about if you over lower it and then think wow the ride is so much better because it's more firm - it's really the bumpstops.
Peter
Peter
St. Jude Donor '09
Thanks.
I pulled the rear bolts and dropped the car onto the suspension to see the rear travel. A stock C5 is on the rear bump stop when the tread of the wheel is at most 1/4" up inside the wheel well...Just something to think about if you over lower it and then think wow the ride is so much better because it's more firm - it's really the bumpstops.
Peter
Peter
Peter
Put the car on the scales with the front sway bar disconnected. Adjust the rear bolts in small increments to get the corner weights equal. If the weights are way off lower the high rear corner and raise the lower one. It shouldn't take much to dial it in. When you get within 20 pounds of cross weight just tweak one of the rear bolts.
Put an adjustabe end link on one side of the front sway bar and reattach the end link so that the bolts slip in and there is no preload on the sway bar.
