DTC code B2723
Old May 27, 2011 | 06:52 PM
duosy's Avatar
duosy
Default DTC code B2723
Theft Deterrent System code B2723 has shut down my 2004 C-5. By luck this happened in my garage. Looking at the GM service manual I require either a scan tool (don't have) or will be forced to have the car towed to a GM dealer (really don't want to do this). Has anyone had this problem and is there a way that I can fix it? I tried three separate keys to see if the electronic plug in the key was the problem. All three keys had been used recently and all three keys couldn't get the car to start. Any help would be greatly appreciated as this is the only car I have to drive to work. Thanks in advance.
Old May 27, 2011 | 10:50 PM
lucky131969's Avatar
lucky131969
Originally Posted by 8VETTE7
Try replacing the Theft Deterrent Relay. Located in the passenger footwell to the left of the IP fuse box and above the BCM and has the following wires going into the wiring base:
Purple, Yellow/black, Yellow, and Red
I disagree. He has a code for the pass key detection circuit. If the BCM was getting the correct resistance from the key, the TDR would work. Possibilities are a lock cylinder, wiring, or BCM for this code(considering he has tried multiple keys)..........not the TDR
Old May 28, 2011 | 11:58 AM
rabnestic's Avatar
rabnestic
Three cheers! It worked for me! Many thanks!! I just had a similar problem and your suggestion and caution regarding jumping the red and purple and having the manual trans in neutral was accurate. I jumpered the red and purple, the car cranked and I replaced the thrift deterrent relay and voila,...back cruising again!
Old Sep 13, 2020 | 12:40 AM
MetalMan2's Avatar
MetalMan2
I know, old thread, but... THANK YOU SO MUCH FOR POSTING. Saved me from a bind.
I was in the midst of errands, when randomly my Z06 wouldn't start (sitting in a Boston Market parking lot, of all places). Starter didn't even try to spin. Battery voltage looked fine. It listed code B2723 CH, which brought me to this thread.
Pulled open the passenger foot compartment, jumpered red and purple while the key was ON (trans in neutral), and it started right up and got me home.
I'll be ordering a replacement relay and ignition switch (for good measure).
Old Sep 13, 2020 | 10:13 AM
rrwirsi's Avatar
rrwirsi
MetalMan2, Sorry for this dumb question, but when you jumped the red and purple wires, did you leave them connected or disconnected them after the car started?
Old Sep 14, 2020 | 01:59 AM
MetalMan2's Avatar
MetalMan2
Not a dumb question at all, I didn't know the answer until it occurred.
When/while red and purple are jumped, the starter spins. You only have red and purple "connected" long enough for the engine to start.
Old Sep 16, 2020 | 03:23 PM
MetalMan2's Avatar
MetalMan2
Just to close the loop... I replaced:Both were replaced before I tried starting the car again, so I can't say if one of them specifically fixed the problem. But the car seems good now! (started up without issue 4-5 times yesterday)
Old Oct 11, 2020 | 04:58 PM
rockymountain1999's Avatar
rockymountain1999
2021 C6 of the Year Finalist - Modified
I’m getting this code now but no “issues” yet but I may go ahead and replace these parts now. Thanks for posting this info!
Old Apr 24, 2022 | 10:00 AM
oldmanonlyfan's Avatar
oldmanonlyfan
2nd Gear
Default Help with DTC code B2723
Hello I have a 99 automatic that I has a code b2723 as well. The car was taken on trade started and ran until I replaced the battery, and this code is all that's showing. I went ahead and tried to by pass / jump the starter. It's cranked starts for a split second and cuts off like it's getting no fuel . I noticed all these were manuals mines and automatic. Is there anything I need to do while starting it ? Foot on brake? Key on I assume? Also is the fix replacing the td relay? Or is something else going on. I was told the car had vats removed? I'm guessing this code and no start suggest otherwise. Any help would be appreciated thanks!
Old Apr 24, 2022 | 10:20 AM
oldmanonlyfan
2nd Gear
Hello I have a 99 automatic that has a code b2723 as well. The car was taken on trade started and ran until I replaced the battery, and this code is all that's showing. I went ahead and tried to by pass / jump the starter. It's cranked starts for a split second and cuts off like it's getting no fuel . I noticed all the one on this post were manual started in neutral. mine is an automatic. Is there anything I need to do while starting it ? Foot on brake? Key on I assume? DO I need to clear code before jumping? Also is the ACTUAL fix replacing the relay? Or is something else going on. I was told the car had vats removed turned off by a locksmith, i actually paid for this service. I'm guessing this code and no start suggest otherwise? I don't see a vats module/catagor on my scan tool not sure if i would , or if he did remove it or turn it off.Any help would be appreciated thanks
Old Nov 28, 2022 | 10:36 PM
frosty_vette's Avatar
frosty_vette
1st Gear
Default Ignition
Did you have to change the key after changing the ignition?
Old Nov 29, 2022 | 12:58 AM
MetalMan2's Avatar
MetalMan2
No, there are 2 parts to the ignition: 1) lock cylinder, that the key goes into; 2) ignition switch, which is allowed to turn when the lock cylinder unlocks it. Replacing the ignition switch doesn't impact the lock cylinder, so you can continue using your existing key.
To DTC code B2723
