ambient temp digital readout on console
Old May 29, 2011 | 09:25 PM
Cat Richmond's Avatar
Cat Richmond
2nd Gear
Default ambient temp digital readout on console
My C5 digital readout of ambient air and driver passenger temps, seems to be out or very dim. Rather than removing the control unit and looking for a bad connection ( no easy task) , could the circut be checked with a diagnostic computer? Could the ambient air sensor or the day/night control eye be faulty and cause this?
Old May 29, 2011 | 09:32 PM
65GGvert's Avatar
65GGvert
No. And no. You'll have to repair the connections if you want it to be bright again.
Old May 29, 2011 | 09:36 PM
jcgunn's Avatar
jcgunn
Search the forum for "Dim HVAC fix" and you will find the 6900+ posts. It is an easy, but delicate DIY fix. You have to remove the bezel, take the HVAC contol apart and re-solder the chips.
Old May 29, 2011 | 09:37 PM
Carcass's Avatar
Carcass
http://forums.corvetteforum.com/c5-t...splay-fix.html
Old May 30, 2011 | 08:31 AM
JOHN MORRISON's Avatar
JOHN MORRISON
Just did the "Dim HVAC Display" fix this weekend. on my '98. Soldering was fussy, but it worked like a champ! About ~ 2 hours and done. GO FOR IT.
Old Jul 7, 2011 | 09:23 AM
captainrjc's Avatar
captainrjc
Cruising
Default repair dim climite control mail order
l live in ma. have permission to print computer co to resolder your problems--did mine acording to instructions on forum--worked out fine--out in and fixed in less than 3 hrs phone # 1-978-772-0100 turn over same day plus shipping--well worth it---
To ambient temp digital readout on console
