clicking from rear end
Old May 30, 2011 | 07:42 PM
ASarsano's Avatar
ASarsano
Default clicking from rear end
ok well was driving my FRC home yesterday and i can hear a clicking coming from the rear of the car upon acceleration and deceleration but it ceases as soon as the car comes to a stop it does get louder when taking curves at more then 20 mpg when at higher speeds noise is not noticable or cant be heard. im assuming wheel bearing, going to put it on the the lift tommorow just bored at work figured id throw the issue up and see what to expect tommorow. thanks
Old May 30, 2011 | 07:45 PM
Bob Chapman's Avatar
Bob Chapman
Could be a worn or broken spline on an axle shaft.
Old May 30, 2011 | 07:47 PM
ASarsano's Avatar
ASarsano
yeah im just hoping its a rather cheap fix only got 500 to trow on a repair any ting more then that and the cars out of commission for a while
Old May 30, 2011 | 08:17 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Not an absolute but probably the easiest fix you'll find. If you hear this clicking when slowly moving out then its probably the splines of the half-shafts have dried out. You'll need to remove the axle nut, get some spray lubricant and lightly spray the splines. Don't over-do it as you might get lube on the brake rotor which would be bad. Put the axle nut back on and torque. I don't remember the torque value this second but its up there. Repeat on the opposite side.
Old May 30, 2011 | 08:28 PM
ASarsano's Avatar
ASarsano
ok sounds good ill check into that thanks
Old May 30, 2011 | 08:59 PM
bumble-z's Avatar
bumble-z
I agree w/ dgrant3830.
Best to check for the simpliest of things first.
Old May 30, 2011 | 09:34 PM
Its_Go_Time's Avatar
Its_Go_Time
Someone needs to explain to me once and for all why these splines need to be greased, apart from ease of disassembly. There is no relative motion taking place between the CV joint and the hub, either rotational or in-out. The two are clinched tight with a big a$$ nut. Why grease it??
Old May 30, 2011 | 10:26 PM
pauly1119's Avatar
pauly1119
St. Jude Donor '06-'11
Had the same problem with my 03 z06. I just tightened the axle bolts and it fixed the problem. I think I set it at 160 lbs.
Old May 31, 2011 | 02:50 AM
Blown_2001Z06's Avatar
Blown_2001Z06
Check the Ebrake and sensor wires. Mine were hanging a little loose and hitting the weights on the wheel used for balancing. Zip tie fixed it.
Old May 31, 2011 | 06:52 AM
guido7834's Avatar
guido7834
I have no idea why, but I had clicking ONLY when shifting my auto from park to drive/reverse. After reading about this on the forum, I did the grease the splines thing and the noise is gone for over a year now!
Old May 31, 2011 | 08:08 AM
dgrant3830's Avatar
dgrant3830
The half-shaft is designed to "slide" in the bearing/hub assembly. Now whether its to turn the sensor, allow for movement while hitting the power, turning or whatever...that spline shaft needs to move in and out of the hub assembly. The splines themselves dry out over the years and the air-gaps and rust, allow the clicking sound to happen.
Old May 31, 2011 | 12:07 PM
imavettegirl's Avatar
imavettegirl
is rear end fluid full?
proper amount of limited slip stuff in it?
Old Jun 1, 2011 | 01:29 PM
ASarsano's Avatar
ASarsano
yup simple problem it turned out on of my break lines had poped out of place and was rubbing on the cv boot, move it back into place put on a new clip. the only problem it is had cut thru the boot so had to order a new one when i called around it turns out its cheeper to just replace the entire axel lol i was shocked 65 bucks for a new axel shipped to my shop next day for free vs a boot for like 75 and 2 week shipping lol so throwing in a new axel tommorow morning. thanks for all the good info ill be sure to keep my eyes on the items listed. fluid its good in the diff, but while im pulling the axel figured ill so a full service so picked up the diff fluid and plan to do the diff and tranny going with the royal purple fluid.
Old Jul 10, 2011 | 03:46 PM
Ahmer's Avatar
Ahmer
So disassembly of the axle is easy??? I heard I have to take apart other suspensions parts as well...
Old Jul 10, 2011 | 03:47 PM
Ahmer's Avatar
Ahmer
I hate my click... it sounds like a 70s Hoopty...
To clicking from rear end
