clutch and flywheel change how much work?
Old Apr 22, 2002 | 11:17 AM
howardl's Avatar
howardl
Default clutch and flywheel change how much work?
I am changing my clutch and flywheel. How much work is it? Do you really have to pull trans /differential and rear suspension?
Old Apr 22, 2002 | 11:39 AM
C5Noir's Avatar
C5Noir
Default Re: clutch and flywheel change how much work? (howardl)
It's a lot of work. You have to drop the rear crossmember, trans/diff and torque tube before you can get to the bell housing.
Old Apr 22, 2002 | 11:50 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
I believe a dealership would charge around 15 hours labor to do a clutch swap.
My father and I did it on jackstands in his garage and it took probably 20-25 hours the first time with us taking our time. It isn't a job for the faint of heart, you REALLY have to tear the car apart to get at the clutch.
Old Apr 22, 2002 | 12:44 PM
howardl's Avatar
howardl
Default Re: clutch and flywheel change how much work? what about special tools required? (howardl)
Thanks ! I thought it looked like a lot of work. What about special tools? I.E. leaf spring compressor etc.?
Old Apr 22, 2002 | 12:52 PM
MattG's Avatar
MattG
We did it without a leafspring compressor or any special tools. One thing that makes lining up the clutch/pressureplate a lot easier is a plastic spline. I think a normal small block chevy one will work.
Old Apr 22, 2002 | 06:00 PM
Tormania's Avatar
Tormania
Cruise-In IV Veteran
Cruise-In V Veteran
It's the kind of job I'd pay someone else to do! :crazy: :crazy: :lol: :lol:
To clutch and flywheel change how much work?
