i have a 01 z06,i have my drivline out at the moment to get my dte diff fixed.was thinking of changing the couplers while its out.
anyone know what size i need and whats the good ones to go with?
12mm or 10mm?
i have a 408tsp motor putting down 500ish to the ground.
spec stage 3+ clutch, if any of that matters
Originally Posted by draggon007
is there two of these in the torque tube then?
Same part number for both.
I've been using the Prothane Six Shooters for a few months now. So far so good. Heard a few good words about the Drive Shaft Shop units as well. RPM uses and sells them.
These are from my 97 with about 59,000 miles and mostly track miles the last 5 years. I had them replaced by the guys at RPM when they put my new/rebuilt transmission in. They said they just get old and dry rot like tires do. They did not have any of the polys at the time but Rodney @ RPM said for my 4/5 HPDE I do OEM would be fine.
I would replace them just cheap insurance and they aren't they easiest things to get to
