Radio Keeps playing
Old Jun 1, 2011 | 07:47 AM
lavery48's Avatar
lavery48
Default Radio Keeps playing
Hello, When I stop and kill the car the radio keeps playing. I can open the drivers door and it still playes. I can then open the passenger door and it stops.Anyone know what's going on here??
Old Jun 1, 2011 | 09:00 AM
4SFED Z's Avatar
4SFED Z
Its normal
Old Jun 1, 2011 | 09:43 AM
MAC5's Avatar
MAC5
Originally Posted by NastyZ
Its normal
Can't specifically answer your question as to "why" the drivers door opening doesn't shut your radio off, but
The radio should shut off when either door is opened.
Old Jun 1, 2011 | 09:46 AM
lavery48's Avatar
lavery48
It's normal?? It didn't use to do it. It just started this.
Old Jun 1, 2011 | 10:13 AM
4SFED Z's Avatar
4SFED Z
Agreed. I mis-read. Yes, should kill radio when either door is opened if I remember correctly. Its been a while ago (bought a Double-Din), so memory isnt the best
Old Jun 1, 2011 | 10:24 AM
1986coupe's Avatar
1986coupe
Check the door switch. If the passenger side is stopping the radio then there may be a problem with the switch on the drivers side.
Old Jun 1, 2011 | 11:43 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Originally Posted by 8VETTE7
Drivers door switch is not working properly. It should kill the power to the radio and other accessories that operate on RAP.
Absolutely correct
Old Jun 1, 2011 | 12:49 PM
lavery48's Avatar
lavery48
OK, I'll check the drivers door switch when I get home today. Thanks for the help folks.
Old Jun 1, 2011 | 01:06 PM
runner140*'s Avatar
runner140*
If thats the only problem you are experiencing, you are blessed.
Old Jun 2, 2011 | 09:01 AM
lavery48's Avatar
lavery48
I'm sure it's the door switch thats causing my problems. It won't lock automicaly or unlock and it doesn't kill the power to radio or turn on the couristy lights. I wonder who sells those? Eckler ?
Old Jun 2, 2011 | 09:06 AM
dgrant3830's Avatar
dgrant3830
Try Gene Culley at www.gmpartshouse.com
Old Jun 2, 2011 | 11:08 PM
toddk's Avatar
toddk
It won't lock automically or unlock and it doesn't kill the power to radio or turn on the couristy lights.
This is likely the DCM, not the switch itself. You should troubleshoot your power locks / window controls further based on this description before attempting to buy parts. It probably is a $zero fix.
The DCM sends messages over the serial bus (OBD-2) to tell the radio to shut off, BCM for courtesy lights/security, and the other door to lock/unlock/window-up/window-down. When you use your key fob to unlock (or the auto-lock as you start driving), that is the BCM messaging the DCMs. Try both the passenger and driver's door window and lock controls, and report what works and what doesn't.
Each DCM controls the "local" resources directly (driver's buttons control driver's window and door lock) so if they work but the "remote" commands fail (opposite door control, key fob, auto-lock), inspect the rubber accordian by the door hinge for a bad/loose/shorted tan wire that prevents these messages from being communicated.
Todd
To Radio Keeps playing
