Import Cluster Swap now gauges off
Old Jun 1, 2011 | 12:11 PM
jfernandez98's Avatar
jfernandez98
Default Import Cluster Swap now gauges off
I installed an import cluster in 98 vette so that I had HUD and swapped out the oil and temp gauges from the original cluster. Now the temp gauge reads about 20 deg higher than the DIC and the oil pressure gauge reads 5 lbs lower than the DIC. Prior to the swap they both were in sync with the DIC readout. The other gauges volts and gas as well as RPM and speed are dead on(did not swap from original cluster) I wasn't sure if it was because I swapped the gauges. Is there anyway to recalibrate the gauges to match the DIC display?
