P0343
Old Jun 1, 2011 | 08:16 PM
youngrigo's Avatar
youngrigo
Default P0343
So Monday i was driving back from LA and my car just died on me. Towed it back home and checked the codes and it threw a P0343. After checking the forums and talking to a shop ive come to the conclusion that i believe the cam bolts have backed out (Guess its a commin problem)
Anyone else have this problem?
Old Jun 1, 2011 | 10:15 PM
Jnape's Avatar
Jnape
Not real common. If you add an F/I setup or have had a cam change, the bolts can be an issue. Torqued to spec and using the proper thread seal is important.
Old Jun 1, 2011 | 10:49 PM
lucky131969's Avatar
lucky131969
....will the engine start? If not, worse case is a timing chain.
Old Jun 1, 2011 | 11:56 PM
youngrigo's Avatar
youngrigo
I have a F/I set up
No the engine wont start... It just died on me as i was cruising down the freeway. I did do some runs friday night and saterday
To P0343
