step 10 on manifold remove
Old Jun 2, 2011 | 04:17 PM
lymygunny's Avatar
lymygunny
Default step 10 on manifold remove
Have done the step by step. On step 10 and can not get the manifold to come up it moves and all bolts but two taped one out!!! Can not get it to come up and towards front any ideas?
Old Jun 2, 2011 | 05:47 PM
TwinTurboZ51's Avatar
TwinTurboZ51
It should come right out. Pull it up and forwards. Only move it about 4- 6 inches forward. Then disconnect the rear vacuum lines and wiring connectors from the manifold. The manifold can be sticky at times. Are you sure ALL the bolts are out and the two rear bolts are taped up high enough to clear? I would lengthen the heater control vacuum line once you have the manifold out as it is too short when you go to re-install. I added about 4" to it. The entire manifold removal only takes about 20 minutes.
Old Jun 2, 2011 | 06:13 PM
lymygunny's Avatar
lymygunny
It seems it wont move forward. Taped bolts up as high as they go but, seems not to go high enough. Hit a plastic lip, almost if the bolts are to long, and wont give. I Can move side to side and up and down just not up and forward. Weird. Okay I give!! It is back together and just need to find someone to do this thing. LOL Gave it one good shot!!! Now I need a shot!!! LOL Have the tube and connector for the re attachment. I wish I knew someone that could do it in 20 minutes!!! I really wanted this relocation of the oil pressure sensor completed.
Old Jun 2, 2011 | 06:44 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
I bet I know what you did. I did the same thing the first time. I thought it was those bolts in the rear, but it was actually one of the coolant pipes I left connected in the front of the manifold.
Old Jun 2, 2011 | 08:51 PM
baxsom's Avatar
baxsom
Do you mean the coolant line that goes through the throttle body?
To step 10 on manifold remove
