99 Corvette Security Light/ No Start
Old Jun 2, 2011 | 06:41 PM
BKC2006's Avatar
BKC2006
Cruising
Default 99 Corvette Security Light/ No Start
I have a 99 corvette and have had a few issues last summer where it would not start. Ive had plenty of camaros with this problem and if you leave the key on for ten minutes it will fire up. Same thing with this car however this year it has done it 5 or 6 times a week. It is getting pretty annoying Im afraid to drive it anywhere and get stranded. Ive rear about a resistor bypass and then read it doesnt work.When I had the car tuned they tuned the VATS off in the pcm. Well that didnt seem to help. Ive read it could be the ignition,the key or even the bcm. I just would like to bypass everything all together. Any Ideas?
Old Jun 2, 2011 | 11:24 PM
BKC2006's Avatar
BKC2006
Cruising
Default my codes..
Here are the codes I pulled out.. TCS: C1232 hc , 1234h... BCM: 2721H .. SDM: U1040 H .. BO-RFA U1096h,U1064h,U1016h,U2120hc.... If any of these are abs codes my abs system isn't working right now.. I just need to have my car start.. Pleeaassee heellpp!!
Old Jun 3, 2011 | 07:18 AM
Fast one's Avatar
Fast one
Try the 30 minute key re-learn procedure. http://forums.corvetteforum.com/c5-t...rt-issues.html
Old Jul 28, 2011 | 08:33 PM
BKC2006's Avatar
BKC2006
Cruising
Fixed..Was the igniton switch the electrical part!
To 99 Corvette Security Light/ No Start
