Clutch Install...
Old Jun 7, 2011 | 12:00 AM
cdkcorvette7's Avatar
cdkcorvette7
Originally Posted by crainholio
I bought a dedicated 15mm wobble socket just for this use. Every extension in my toolbox clicked together plus this makes the job as easy as can be.
That's how I did it too...
As for the pilot bearing... Did you feel like you had to FORCE the shaft into place with the c-clamp? If everything is aligned right it should just slide into place (it took me and another guy the better part of a half hour to get this right...). If you forced it you very likely damaged the pilot bearing and it would be a lot easier to check it out now than it would to start from scratch in a couple weeks... Just a suggestion.
Old Jun 7, 2011 | 12:28 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Everything is put together and running great. No noise, all seems to be running great.
If things change, I will post up how jacked up I am.
Micah
Old Jun 7, 2011 | 01:01 AM
Dope's Avatar
Dope
Resident moron
Originally Posted by mph1972
I appreciate all of the recommendations, suggestins, comments and "you are going to regret" remarks. Problem with this all is, everyone has "their" way of doing it and we did the c-clamp method. I am really hoping that everything just played friendly and we are going to be fine, but that will only be determined this afternoon when we start it up and drive it. I am doing my car in a couple of weeks and I already know that I am doing some things different.
Yes, exactly. Everyone has their own way of doing it, there is no single "right" way. The c-clamp method is fine, it's what I used to do my clutch install guide something like 8 years ago. Car is still fine so obviously it's a legit method. You just have to use common sense.
If you have to use 2 hands and a pipe extension on the c-clamp, then it's not lined up and you're gonna damage the pilot bearing or crack the cast aluminum bellhousing or torque tube.
If you're just using the c-clamp to gently guide the input shaft in while working solo, you're fine. Not all of us have competent help available. To be honest, the hardest part of that operation was getting the splines lined up. Once I got past that part it all glided together easily.
Dope
Old Jun 7, 2011 | 03:10 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
Dope
I feel ya. I took the car out for a spin with the owner in the passenger seat and everything felt great. It was a relief to know that the mystery was history at that point WRT the pilot bearing and all.
Thanks again everyone for chiming in.
