where do these wires go?
Old Jun 6, 2011 | 01:24 PM
allen2m4's Avatar
allen2m4
Default where do these wires go?
well my belt broke at the strip last night and in doing so it took some wires with it.
now my question is where do they go? when it happened i got a bunch of messages on the DIC. shocks inop,ride control inop,tcs inop,abs inop, and said no more than 80mph.
it looks like they where running along the passenger side by the ac compressor. it looks like its only four or five wires.
pics.
Old Jun 6, 2011 | 08:27 PM
allen2m4's Avatar
allen2m4
No one ?
Old Jun 6, 2011 | 08:58 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Looked at mine and...
I've got some wires the are purple/beige and red/blk/yellow that go to the MAF?
Where do the wires feed to/from?
Bob K.
Old Jun 6, 2011 | 09:00 PM
lucky131969's Avatar
lucky131969
Originally Posted by allen2m4
No one ?
Look closely at the wire colors, hard to see in the pic.
The only twisted pair, and twisted triple wires I can think of in that area would be for the position sensor, and shock solenoid.....which would make sense.....given the codes you have.
Are they as follows?
Purple/white stripe
Tan/white stripe
Light blue/white stripe
Gray
Light blue
Old Jun 6, 2011 | 09:01 PM
lucky131969
Bob K.
Doubtful.....the wires are twisted pairs/triples.
Old Jun 7, 2011 | 02:29 AM
allen2m4's Avatar
allen2m4
colors are
bundle of three:
blue,black stripe
purple,white stripe
tanish yellow,white stripe
bundle of 2
grey
blue
also looks like it was 2 seperate wire bundles down in there i see a green and a tanish wire also
Old Jun 7, 2011 | 05:31 AM
jirasvet's Avatar
jirasvet
As stated by lucky131969 those appear to be for the suspension,
here are 2 schematics confirming the colors, also those are shielded wires
[IMG][/IMG]
Old Jun 7, 2011 | 08:43 AM
lucky131969
Shielded?
Old Jun 7, 2011 | 09:43 AM
allen2m4's Avatar
allen2m4
Originally Posted by lucky131969
Shielded?
x2?
Old Jun 7, 2011 | 09:47 AM
lucky131969
x2?
What is "x2" ?
Old Jun 7, 2011 | 11:16 AM
jirasvet's Avatar
jirasvet
just that they are supposed to be twisted, and not run straight
from the 2001 manual
"Twisted-pair wires provide an effective shield that helps protect sensitive electronic components from electrical interference. If the wires were covered with shielding, install new shielding.
In order to prevent electrical interference from degrading the performance of the connected components, you must maintain the proper specification when making any repairs to the twisted-pair wires shown :
The wires must be twisted a minimum of 9 turns per 31 cm (12 in) as measured anywhere along the length of the wires
The outside diameter of the twisted wires must not exceed 6.0 mm (0.25 in)
Old Jun 7, 2011 | 11:24 AM
lucky131969
Right, but you can see by the schematic symbols, that the wires are twisted, not shielded. Running twisted signal wires was implemented many years ago on aircraft, where long wire runs were subject to interference. I believe the Bose system does employ twisted and shield wiring.
Old Jun 7, 2011 | 12:50 PM
allen2m4's Avatar
allen2m4
What is "x2" ?
"times 2"
as in i also have no clue
so question, i went and looked at some wrecked vettes and they were the z51 package. they didnt have those purple wires all i saw was a tan and green wire that went to both wheels. so if i took my f45 system out and just went with a z51 suspension would i have to do anything with these wires or do something in the pcm so they didnt recieve signal anymore?
Old Jun 7, 2011 | 02:07 PM
lucky131969
"times 2"
That's a whole new thread on deactivating the suspension. You can also find a procedure if you search.
Old Jun 8, 2011 | 11:42 AM
allen2m4's Avatar
allen2m4
i understand that. my question is ,is it possible? i dont "have" to repair these wires if i delete the f45 option? i can get different shocks thats not a big deal.
i also found a green and tan wire broken, it was in its own harness and from what it looks like it runs to both front wheels>?
i know you need a tech 2 and unplug them but is it possible?
Old Jun 8, 2011 | 12:39 PM
jirasvet's Avatar
jirasvet
could be wires to the wheel speed sensors for the ABS, but the schematic
only shows one set of green and tan wires. hope this helps
I can't give you any info on conversion
[IMG][/IMG]
Old Jun 8, 2011 | 01:59 PM
Daddyrama31's Avatar
Daddyrama31
Don't know much about this stuff but I know Jirasvet does.
To where do these wires go?
