Emergency cable slack
I don't understand the "roll-backwards" theory. There is absolutely nothing inside the drum brake assembly that will make the e-brake self-adjust if you apply the e-brake while rolling backwards.
Peter
It's not a "theory". The mechanism may not work very well, or could have been designed a bit better, but it's designed to do just that.
When correctly adjusted, the PB lever will click 11 times when fully applied, placing the lever approx at a 45* angle and it will be in the mid-range of it's total range of travel.
Unless you're driving around town with the brake applied, lining/drum wear is almost nill, so there is nothing to adjust for anyway. Slack in the cable has to be adjusted for at the cable adjuster, not at the shoes.
It is a nice theory though.
People have been yakking on here for years about backing up to adjust the parking brake. There is NOTHING in there that will move the star wheel by backing up, pulling the brake lever, or whatever. As you mention, the star wheel is for manual adjustment. I believe all the yanking up on the handle does is loosen whatever dried grease is in the mechanism so that the auto slack adjuster in the base of the lever can do its job.
Good Luck
Bill aka ET
Good Luck
Bill aka ET
Far be it from me to "butt heads" with an expert.
This is a cut & paste from your Parking Brake Adjustment Tech Tip on this site:
"...roll the car backwards on a hill.. or in reverse @ 5
mph..pull up on the e brake lever... this will slam your car to an abrupt
stop.. the engagement of the shoes to the drum while the car is moving
backwards will cause the shoe assembly to flex.. it is the flex that
causes the blade to click the adjusting star one click... Do this three or
four times and it will expand your shoes.. "
I don't seen any adjusting blades near my star wheels. But then I'm just a butthead!
Why are you getting so defensive, Bill?
You answered the OPs question very succinctly. He knows his cable needs adjusting, and now he knows how...from at least four different people, including yourself. No one is questioning your GM technical engineering services knowledge.
This thread went on a tangent, and there's nothing wrong with that. Sometimes that's when they get really interesting and informative. We're all here to learn new things and hash out ideas, Bill. Why don't we check the name-calling at the door and grow our Knowledge, not our Egos.
This constant talk that the adjustment procedure be done while moving in reverse is probably what causes many people, including myself, to quickly *assume* that the adjustment is being done inside the brake. The cable adjuster doesn’t care which way the car is going in order to operate properly. The car doesn't even have to be moving for it to operate. These e-brakes don’t have any servo action like regular drum brakes do, so they grab the same going fwd or backwards. I can feel perfectly well if mine is working while moving forward. Why the constant need to do it while rolling in reverse? I bet if we took that word out of it, us buttheads wouldn’t have anything to argue about anymore. Does anyone even remember how drum brakes used to self-adjust...
Explain again, please, WHY BACKWARDS?? What do you mean "feel the mechanism work in full engagement"?
Completely unrelated, but I really have a warm spot in my heart for crotchety old farts. The have so much wisdom and experience to offer, but for some reason the younger generations just don't give a damn. I have never understood why. On the decidedly remote chance that I ever find myself old and wise, it would probably **** me off too.
This constant talk that the adjustment procedure be done while moving in reverse is probably what causes many people, including myself, to quickly *assume* that the adjustment is being done inside the brake. The cable adjuster doesn"t’t care which way the car is going in order to operate properly. The car doesn't even have to be moving for it to operate. These e-brakes don’t have any servo action like regular drum brakes do, so they grab the same going fwd or back wards. I can feel perfectly well if mine is working while moving forward. Why the constant need to do it while rolling in reverse? I bet if we took that word out of it, us butt heads wouldn’t have anything to argue about anymore. Does anyone even remember how drum brakes used to self-adjust...
You are right backwards or forwards works... the reason you allow the car to roll ( on a hill ) is that it give momentum to the car so you can feel the engagement of the shoes. if you pull up on the lever and are not able to stop the car, then you need to adjust the shoes, the shoe to drum clearance is not changed by the adjustment of the cable. The cable adjustment is there to allow enough throw to engage the shoes to the drum under enough pressure to hold the car. determining if the shoes need to be adjusted can not really be done unless the car is moving.. this procedure also works to check the disengagement of the shoes.. I tell people all the time to make the shoe diameter as tight as possible but still be able to get the drum over the shoes. Ideally the shoes engage the drum and the lever is at 45 degrees and locks up the shoes dramatically. you will also See with the roll back., method that the shoes will indeed disengage at 35 degrees, leaving no concern about the shoes being adjusted too tightly..
As far as the sarcasm and irreverence, thats just me... and my coping mechanism . Ive been here for ten years, I don't come here to get advice but to give it... I don't get paid to do this... I have over 12,000 open forum help post and almost 15000 private message post... The disrespect I get by some members here is the reason I act the way I do... It's very frustrating to give my time to help and have some people go out of their way to disrespect me.
You really have to know me.. if it wasn't for the fact that a lot of my blood flows through these cars , and I truly care about the members experience with this car, I could just as easily leave... I use to spend ten hours a day here helping members..I have a lot of things on my plate, grandchildren, a 44 year marriage, I also deal with a Photographic forum ( ten years there ) and a shooting forum.. Plus , I shoot competitively twice a week, and do 2 hours at the gym, 6 days a week. I am busier now than before I retired, I still find time to help here but do not like having to deal with the disrespect... BTW,,, I never start any of this.. I come in and try t set the OP straight.. typically I also add some of my scarcasim... in a way that makes it seem as if ( in this case ) the logical thing was to change a 20 dollar belt... was it a little sarcastic?? sure.. but it was good information and it didn't cost the OP 90 dollars an hour...
Nice post thank you
Bill aka ET
If they seem to rub a little right at first,drive a few miles,no more rub.
Dope
I can agree that testing the e-brake with a rolling car to check can be a good idea. However, the reversing is not required and just saying to back up and yank on the handle to adjust it without explaining why is doing an injustice to the community. Posting to do that is why that adjustment method for the e-brake shoes keeps popping up. My car was on jack stands when I adjusted my e-brake and it works fine.
And, after all that, the problem still goes back to what I first posted about the handle. If it's not adjusting the cable slack then the handle is either all gummed up with old grease or it's broken.
Peter
