Bellanger headers won't pass smog in CA????
Old Apr 22, 2002 | 08:13 PM
Rhynos99's Avatar
Rhynos99
Default Bellanger headers won't pass smog in CA????
Is this true? I was looking to get these put on but I was informed that these will not pass visual inspection at time of smog. Is this right? if so does anyone know how often you need to get a smog check out here. I know on 2k's and up it's every four years I think. I have a '99 and just purchased it last November. I know I run the risk of this f'n smog thing but I also don't want to dump a couple grand into it and then not be able to drive it. Any help???? :confused: :confused:
Old Apr 22, 2002 | 08:18 PM
blackjack's Avatar
blackjack
Default Re: Bellanger headers won't pass smog in CA???? (Rhynos99)
That's why I run the B&B shorties. They're the only headers that I could find that are CARB certified.
BlackJack :flag
Old Apr 22, 2002 | 08:20 PM
Rhynos99's Avatar
Rhynos99
Default Re: Bellanger headers won't pass smog in CA???? (blackjack)
Yeha but the Bellangers give more HP right? Where do you see this gain, low end? high end? accelleration? all around?
Old Apr 22, 2002 | 08:30 PM
blackjack's Avatar
blackjack
The Bellangers will give you more torque. The B&Bs kick in around 3000 RPM. I sacrificed the extra power just to pass smog. They sure sound mean with the Corsa Indys though :D
Old Apr 22, 2002 | 09:15 PM
yllwfvr's Avatar
yllwfvr
Blackjack, how loud are the B&Bs and Indys at cruising? Can you hold a conversation w/ a passenger without yelling? I have the Indys and was thinking of getting those headers or the JBA shorties. Thanks... :cheers:
Old Apr 22, 2002 | 09:53 PM
allanlaw's Avatar
allanlaw
No smog check until the car is at least 4 model years old. For example, my '98 has not been smogged yet. However, after that, it needs a smog check every other year.
Old Apr 22, 2002 | 10:19 PM
LTD's Avatar
LTD
While I have no idea what things are like on the left coast, in Virginia there are plenty of "incompetent" mechanics that will pass just about anything. :-)
Perhaps you just need to find the right shop.
Old Apr 22, 2002 | 10:27 PM
Z06 Mike's Avatar
Z06 Mike
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Bellanger headers won't pass smog in CA???? (LTD)
I had the same questions and Craig @ West Coast Corvetttes was the Answer Man for me. There are a lot of folks selling mod's that just won't pass our tough smog standards here on the Left Coast.
Old Apr 22, 2002 | 11:01 PM
Speeder's Avatar
Speeder
I smogged my 99 coupe before I sold it. It had TPIS headers. Pass the sniffer with flying colors. The tech who passed it didn't even question the headers. :D
Old Apr 22, 2002 | 11:31 PM
4DCYKEY's Avatar
4DCYKEY
Default Re: Bellanger headers won't pass smog in CA???? (Speeder)
I'll bet that most techs won't know the difference between stock exhaust manifolds and headers...and if you are concerned, find a "friendly" tech who is just interested in whether your car pollutes, not how it looks. After all, isn't that the whole reason for smog tests -- determining whether one pollutes or not?
Herb
Old Apr 23, 2002 | 12:10 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
No Long Tube Headers will pass visual in Cali! Andy Green has TTS Long Tube Headers in his 97 and he passed.
Old Apr 23, 2002 | 12:28 AM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
The only thing that did not pass inspection on my old LT1 Camaro was the LG crank case breather. I had very visible headers and he did not even mention it. Arco smog station.
Old Apr 23, 2002 | 02:41 AM
Rhynos99's Avatar
Rhynos99
Default Re: Bellanger headers won't pass smog in CA???? (OCMike)
Thats where I went for info. Spoke to Neil and he's the one that filled me in. The more I think about it if it passes the sniffer then you are right about most guys not knowing anything about the mods.
Old Apr 23, 2002 | 11:32 AM
Z06 Mike's Avatar
Z06 Mike
Good point Herb...I bought my '02 Roadster out of state last January so I had to have it smogged before I could register here in California. I took it to a local Arco Smog Pro's and I could tell they do not see many Corvette's. They had to make a phone call to find out where the inside computer plug is located. They asked if my car was "stock" and I said, "Yes, for the most part." (I had the Corsa's, X-Pipe, Ram AIr Induction on it).
I guess the dice roll is if it passes the sniff test and the tech isn't a "by the book" dude, you may be OK.
QUESTION: If you fail due to the visual, can you simply try another shop or is there some sort of state-wide computer record generated?
Old Apr 23, 2002 | 12:26 PM
blackjack's Avatar
blackjack
Default Re: Bellanger headers won't pass smog in CA???? (yllwfvr)
Yllwfvr,
It's still quiet inside until I open the throttle.
Then it really screams. :eek:
No added resonance while cruising.
-BlackJack :flag
Old Apr 23, 2002 | 01:32 PM
ddawson's Avatar
ddawson
OCMike,
You can just go to another shop. The state record only shows FAILED unless you were a gross polluter.
Its a gamble that I have taken many times before. It got old worrying about passing and dealing with different shops.
You still pay each time you take the test.
I bought a Saleen S351R out of state and it wouldn't pass at all. The Mustang Performance shop knew people who could get it passed but it would cost several hundred $$$ every other year.
Get the headers with the CARB number and don't worry about it.
Old Apr 24, 2002 | 09:20 PM
Z06 Mike's Avatar
Z06 Mike
Default Re: Bellanger headers won't pass smog in CA???? (ddawson)
Thanks Dan.
To Bellanger headers won't pass smog in CA????
Old Apr 24, 2002 | 10:36 PM
JWSchmidt3's Avatar
JWSchmidt3
I say go for it, the Belanger's are awesome, and well worth it. Best LT header on the market, bar none IMO. :cheers:
Old Apr 25, 2002 | 11:28 AM
wwashing's Avatar
wwashing
The California visual inspection is just a way of collecting a huge tax from parts manufacturers. It's only to check for the CARB number. It costs big bucks to go through the Beauracrazy and obtain a certification. The significant (to the smog issue) part of the cert process is to test the part on a car to see if it pollutes. A pollution test takes less than an hour and costs about $50, way less than the thousands they charge manufacturers for a cert number. This is why many manufactuers don't bother to get certified.
The real issue is pollution and just adding headers has no affect on a car's polluting. If it did it would get caught in the smog test and dealt with at that level, as it should be.
And that's my $.04!
Old Apr 25, 2002 | 03:03 PM
4DCYKEY's Avatar
4DCYKEY
Default Re: Bellanger headers won't pass smog in CA???? (wwashing)
And that's my $.04!
Hey Bill,
How come your input is worth twice everyone elses???
Herb :)
