RSD Help, What now?
Old Jun 10, 2011 | 06:48 PM
BRISLS1's Avatar
BRISLS1
St. Jude Donor '11, '14,’19
Default RSD Help, What now?
How do I get the boot on this thing?
Old Jun 10, 2011 | 07:14 PM
johnnyzvette's Avatar
johnnyzvette
take the hurst shift **** off, put it back on after you reassemble all the other parts first.
Old Jun 10, 2011 | 07:55 PM
BRISLS1's Avatar
BRISLS1
It won't move. How much twist is too much?
Old Jun 10, 2011 | 08:11 PM
bumble-z's Avatar
bumble-z
If you are talking about removing the Hurst ball, there is a nut under the ****.
Using an 11/16"(?) open end wrench, loosen the nut from the ball, then turn the ball off the shaft.
If you get that done, give me a pm & I will give you the info that will make your stock boot, properly fit the new shortened shifter.
Old Jun 10, 2011 | 08:20 PM
BRISLS1's Avatar
BRISLS1
IT was like 5/8 inch. But that did it.
I just cut along the threads for about an inch of the boot to get the opening wider, turned it inside out, and zip-tied it to the post of the shifter, then re-installed the Hurst ball.
Thanks for the Help!
Old Jun 10, 2011 | 09:29 PM
bumble-z's Avatar
bumble-z
There was no need to cut the threads out of the stock boot.
Oh well.
To RSD Help, What now?
