Question - charging my battery
Old Apr 23, 2002 | 05:11 AM
VettesRule's Avatar
VettesRule
Default Question - charging my battery
Can I put a trickle charger on my 2001 Z06 battery without disconnecting the cables?
I have been traveling and want to charge it up.
Old Apr 23, 2002 | 12:48 PM
carpe dm's Avatar
carpe dm
Default Re: Question - charging my battery (VettesRule)
You can, especially if it is a "Battery Tender" or other low voltage unit. If you use a regular "charger", I would take it out just to be on the safe side. :)
Old Apr 23, 2002 | 01:17 PM
Square's Avatar
Square
Default Re: Question - charging my battery (carpe dm)
My battery charger has a 2AMp. 10Amp, and 50Amp/Jump Start settings. I have had to charge the battery several times. Here is what I do:
Leave the battery connected
With the battery UNPLUGGED :
connect the positive cable to the positive terminal
connect the negative cable to the bracket that hold the alternator(one clamp will slide right in that slot so it is very secure)
set the charger to the 2Amp setting
Plug in the charger. :seeya :chevy
Old Apr 23, 2002 | 02:03 PM
pjazz's Avatar
pjazz
C6 of Year Winner (performance mods) 2019
I used a battery maintainer while in storage for 4 months without disconnecting the battery. I had no problems when I finally started it. With a maintainer or tender it will only cut on when the batteries voltage goes down. I think with a trickle charger you have to make sure it doesn't over charge.
Old Apr 24, 2002 | 05:25 AM
VettesRule's Avatar
VettesRule
Default Re: Question - charging my battery (pjazz)
Thanks!
To Question - charging my battery
