Horn quit working - any ideas?
Old Apr 23, 2002 | 11:47 AM
SEAMOORE's Avatar
SEAMOORE
Default Horn quit working - any ideas?
My horn on my 99 FRC just quit working. I checked the fuse. It's o.k. I swapped out the horn mini relay in the engine compartment fuse box w/ the fog light mini relay and it started working, checked it 4 or 5 times. Today, on the way to the office i checked it and it wouldn't work. Any ideas? Thanks for your response in advance. I'll be away from the computer until tomorrow and then will check all your comments. Thanks Update:
Three times today horn has quit working, started working, and quit working again. If its the contacts in the steering wheel is it a fairly easy job to do yourself or should i take it to the dealer. The car is still in warrenty, just don't like to leave it. Thanks :flag
[Modified by SEAMOORE, 4:50 PM 4/23/2002]
Old Apr 23, 2002 | 12:20 PM
jerryv's Avatar
jerryv
Default Re: Horn quit working - any ideas? (SEAMOORE)
See if the horn will sound when the security system is violated. If so, it's probably the horn switch or a bad connection in the steering column.
Old Apr 23, 2002 | 12:35 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: Horn quit working - any ideas? (Jerry Velders)
Kinda OT; but seen a bumper sticker that said:
Horn is broken
Watch for finger
Old Apr 23, 2002 | 01:05 PM
MAGRED 02's Avatar
MAGRED 02
My horn went out on my 99 Coupe, the contacts in the steering wheel were dirty and kept the horn from going off.
Old Apr 23, 2002 | 06:59 PM
SEAMOORE's Avatar
SEAMOORE
TTT
Old Apr 23, 2002 | 07:21 PM
SR71's Avatar
SR71
Mine quit too.....oh yeah, I forgot to flip the switch that toggles it between beeping the horn and activating the nitrous relay.....stupid me!!! :D
Old Apr 24, 2002 | 10:34 AM
Fast one's Avatar
Fast one
Default Re: Horn quit working - any ideas? (SR71)
If the horns are drawing excess current they will burn out the relay contacts. Horns used to have an adjustment screw on them, I don't know if the C5 does. Try checking the current draw for each horn and compare to each other; just unplug the car wires to the horns and use a wire directly to the battery or battery charger. If the horns have an adjustment screw you can place a rag into the horn and adjust the screw with 12 volts applied to them.
To Horn quit working - any ideas?
