My rear tires are rubbing very slightly on the inside of the wheel well going over bumps with the lowered stance on the LG coil overs and wider 305/35/18 tires so Im thinking about using a 1/8 or 1/4 inch spacer on the rears. Any safety concerns with wheel spacers? Any preferred brands?
I just purchased these from DRM. I got the 3/8 and the 1/2 longer studs. the customer service and the quality in their work is what sold me. I am looking for them to arrive today UPS. http://dougrippie.com/?cat=34
I went to 19 inch on my rear with 305's I had to add a 1/4 inch spacer for the same problem.4,000 miles and raced weekly with no problems.I do put a torque wrench on them about once a month just to be safe.
thanks...did you go with longer wheel studs with the 1/4 inch?
These spacers that I linked to are hub centric and carry a tolerence of .0005 that 1/2 a thousandth. pretty tight. Randy at DRM explained to me that they do not make a 1/2 spacer because the hub centric on the OEM hub is 1/2. Thus is why the go from 3/8 to 5/8. The 5/8 spacers are machined with the centric into them.They are also $239.00 He also said that you do not need the longer studs with the 1/4 spacers. I did by using the 3/8 I lost 1/8 thread length.
I bought the Mr. Gasket 5/16" universals you find at most parts stores to use on my GTO while I had it. Then I transferred them over to the vette when I traded. Have had no problems with them throwing anything out of balance or any issues with them trying to back the lugs off. I kept the stock studs.
We offer a set of 1/8" wheel spacers as well. They are anodized black for extra durability and longevity, and are hubcentric for ease of installation. Sounds like if the OP is barely rubbing, and has a little space between tire and fender, the 1/8" spacers are going to take care of his issues!
personally I would stay under 1/4 inch with stock studs. I run spacers on all four corners without any issues. All my miles are done on the track and I do check the torque after each track session.
I use ccw 1/4" spacers on my drag race wheels (18x11.5 ccw classics). I get around 7 turns on them til they're tight, and so far they're fine. I only use them for drag racing, and I'm not sure I'd want to run them w/o longer studs for everyday usage.
Randy and his father are number one people to work with. I have purchased a number of their products-all first class quality and workmanship. I bought their 5/8" spacers and hi-tensile studs for the front of the vert when I put the big brakes on.
