P1518 Problem
Old Jun 20, 2011 | 07:18 PM
Arober9386's Avatar
Arober9386
1st Gear
Default P1518 Problem
I have a problem with my vette, It started as it was cranking like it was not getting gas then turned out that it was like the starter was not engaging and will not start. I let it sit and it will fire right up. A couple of times the reduced power message has come up and when I shut the engine off it will restart started right up fine. The code that is coming up is P1518. The battery is new and the conections look good. Need help figuring it out and I am not a machanic so please make it simple
Old Jun 20, 2011 | 10:56 PM
87SAM's Avatar
87SAM
Just in case you didn't see it:
http://forums.corvetteforum.com/c5-t...and-p1518.html
