Odd fuel problem
Old Jun 20, 2011 | 11:41 PM
9020v's Avatar
9020v
Default Odd fuel problem
I've had my Z06 for a few months and am getting ready to sell it. The only real issue I've had with it has been with the fuel system. When I bought it, it had the dead fuel gauge problem, which was explained to me as caused by a dirty fuel sender by the previous owner. I have read about the duel fuel tank setup in these cars and am trying to troubleshoot my problem.
On my first fillup, I put in BP 93, and shortly after the fuel gauge started working. I continued using BP 93 and then the gauge died again. I then tried some seafoam in the tank, filled up with BP 93 again and cleared the codes. The fuel gauge has worked since, except a few weeks ago I ran out of gas when the fuel gauge was at about 3/8 of a tank. It took me a while at first to troubleshoot it as no fuel! I took it to the station, put 5 gallons in it, drove it about 10 miles, then it only took about 7 gallons when I got it back to a BP station to fill it the rest of the way up. So the car went from out-of-gas to full in a little less than 12 gallons.
Obviously sounds like a problem with the fuel transfer system. Anyone have any tips for solving this issue once and for all?
Thanks!
Old Jun 21, 2011 | 12:00 AM
Carcass's Avatar
Carcass
Amazing what 15 seconds of searching will turn up...
http://forums.corvetteforum.com/c5-t...m-failure.html
Old Jun 21, 2011 | 09:30 PM
9020v's Avatar
9020v
I searched the web for info for a while for posting, where I learned about the fuel system design in this car. I appreciate your superior web surfing skills, but his problem is a little different than mine, although the information there was helpful, so thank you.
I am still unclear as to whether I can simply remove and clean the RH jet pump or if I need to buy a new RH Sender/Jet Pump Assembly.
Also, how did he know that the left hand tank was drained of fuel? Is he just assuming that since the pump draws off the LH tank or was he able to inspect the fuel levels in each tank some way?
Thanks!
To Odd fuel problem
