Indexing an Actuator
Old Jun 21, 2011 | 09:45 AM
lavery48's Avatar
lavery48
Default Indexing an Actuator
I repaired the A/C Actuator on pass. side and now I need some good-easy-steps on how to reindex it.
Old Jun 21, 2011 | 07:36 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Now I don't truly know and someone else might have your answer but I don't think it needs to be indexed. I think you just put it in, clear the codes, so that it recalibrates itself. I think or believe...not sure, that it works by figuring out where the stops are by loading when the dampers open or close. The headlamp motors work the same way with the headlamp controller.
