EBCM codes after ABS fixer repair
Old Jun 21, 2011 | 08:43 PM
Jumper11's Avatar
Jumper11
Default EBCM codes after ABS fixer repair
I had my EBCM repaired by ABS fixer because of ABS, Handling system and traction control system warning. Got it back and all was good until last week the warnings came back on. I drove the car to work with the light on. Started it up to go home and haven't had the light since. Has anyone experienced this temporary warning?
Old Jun 21, 2011 | 08:57 PM
coia96vette's Avatar
coia96vette
Check your codes. If you are getting C1287 and/or C1288 it's the swps (sterring wheel positioning senser). Just replaced mine yesterday and all is fine now.
Old Jun 21, 2011 | 09:00 PM
Jumper11's Avatar
Jumper11
I'll check them tomorrow, but again the problem has not returned.
Old Jun 21, 2011 | 09:01 PM
Jumper11's Avatar
Jumper11
Do you have the gouge on where the sensor is and how to change it?
Old Jun 21, 2011 | 10:31 PM
coia96vette
Sensor is on steering column down by the firewall on the inside. Yellow and green disc shape. GM Partshouse has them for about $63.15 plus shipping. About a 3 hour job to replace with proper tools.
Old Jun 28, 2011 | 12:52 AM
jims01vette's Avatar
jims01vette
Can you tell me where the sps sensor is? Sent my ebcm in and getting the same codes 1287-1288. Thanks , jim
Old Jun 28, 2011 | 09:53 AM
GoBallsDeep!'s Avatar
GoBallsDeep!
forums.corvetteforum.com/c5-tech/1671631-any-tips-on-replacing-the-steering-wheel-position-sensor.html
Old Jul 5, 2011 | 12:18 PM
jims01vette
Default Sensor
COIA, when you say inside, are you talking inside the car? and what tools are you talking about.
Old Jul 5, 2011 | 02:28 PM
GoBallsDeep!
^ Jim, copy and paste the link I posted into your browser. It goes through the procedure in detail with plenty of pics.
To EBCM codes after ABS fixer repair
