Unknown Warning Chime - PLEASE HELP
Old Jun 21, 2011 | 09:51 PM
bmr5100's Avatar
bmr5100
6th Gear
Default Unknown Warning Chime - PLEASE HELP
Today I took the key out of my '98 c5 and the warning chime starting beeping like the headlights were left on or something. I have no idea what is causing this chime. When I get out of the car and shut the door the chime stops but when I open the door again the chime begins again.
Anyone know what is causing this chime??
Old Jun 21, 2011 | 10:07 PM
1986coupe's Avatar
1986coupe
Fog lights? Interior lights? Not in Park? Any codes?
Old Jun 22, 2011 | 12:11 PM
bmr5100's Avatar
bmr5100
6th Gear
None of the above.
It must be something simple it has to be. When I remove the key from the ignition doors are supposed to unlock, they don't. This just started yesterday. I then have to press the unlock button in the car and then when I open the door the chime starts.
Old Jun 22, 2011 | 02:57 PM
1986coupe's Avatar
1986coupe
What is the condition of your battery? A weak battery can have an effect on C5 electronics.
Old Jun 22, 2011 | 04:58 PM
bmr5100's Avatar
bmr5100
6th Gear
battery was replaced last month the car has 13k miles on it
Old Jun 22, 2011 | 08:09 PM
1986coupe's Avatar
1986coupe
Gas door? Back hatch/trunk?
Did I already say fog lights or the lights on your mirror?
When the battery was changed did all of your optional setting remain the same?
I can't replicate the problem with my 2001. I am just listing the simple stuff because it is cheap to fix but usually frustrating to find. The rest could potentially be expensive.
Old Jun 22, 2011 | 08:57 PM
LoneStarFRC's Avatar
LoneStarFRC
Aha! There's your problem. Battery is too new.
Old Jun 23, 2011 | 11:51 AM
corvettebob1's Avatar
corvettebob1
I'll bet your ignition key cylinder is messed up, there is a couple of brass contacts that touch the resistor pellet that can get bent as the key cylinder gets worn.
You may be able to just put something non conductive in far enough to move the tabs and if the chiming stops there is your answer.
Old Jun 23, 2011 | 11:56 AM
bluvette79's Avatar
bluvette79
i have this problem with my navigator. the car thinks the key is still in the ignition. i tried some lubricant/cleaner on the ignition but it didn't work much better. maybe some would work for you. no real issue for me but i don't have auto lock/unlock set so you have more aggravation! not worth tearing into the ignition switch imo.
To Unknown Warning Chime - PLEASE HELP
