Service Active Handling message C1288
Old Apr 24, 2002 | 12:31 AM
rgee's Avatar
rgee
Default Service Active Handling message C1288
I just got a "Service Active Handling" message on my display. I searched the forum and learned how to check DTC codes.
I have
28-TCS C1288H
60-IPC U1160H
A0-LDCM U1064H
B0-RFA U1000H
B0-RFA U1064H
After checking these codes I started and drove the car. No more messages.
Are any of these serious? :confused:
2001 Lt. Pewter Coupe - Oct 2000 delivery
Old Apr 24, 2002 | 08:24 AM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
Default Re: Service Active Handling message C1288 (rgee)
All of those codes have an "H" indicating History/old codes; none have a "C" for Current. Reset your system & see if it pops up again.
BTW here is the list of codes... http://c5.techbottle.com/DTCcodes.htm
[Modified by Sully C5, 7:25 AM 4/24/2002]
Old Apr 24, 2002 | 04:19 PM
MagRedVette's Avatar
MagRedVette
Any particular weather conditions this happens in? My 2000 used to display the "Service Active Handling" message if it was wet outside or raining. One of the wiring harnesses apparantly is susceptible to chaffing, and when it does, you get moisture in the wiring and it throws this code. Took it in and had it back the same day.
Old Apr 24, 2002 | 05:55 PM
rgee's Avatar
rgee
Default Re: Service Active Handling message C1288 (MagRedVette)
The weather was dry and in the 80's.
Also regarding Sully C5 response: Since when I restarted the car, if the error message doesn't come up, does it change to H for history since it is no longer 'C' for current?
Old Apr 24, 2002 | 06:13 PM
Sully C5's Avatar
Sully C5
To quote the text...
"There are two kinds of DTCs, "Current" and "History," designated with a letter suffix, "C" or "H". A current code indicates that the malfunction is present in the system whose module is displaying data. A history code indicates a problem existed in that module sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it is possible it's evidence of a previous problem. Now solved, that was not removed by clearing codes. More likely is that a history code indicates an intermittent malfunction."
Old Apr 24, 2002 | 06:17 PM
georgec114's Avatar
georgec114
There's a TSB 01-05-25-004 for this. Just had mine uploaded at dealer today. I would get the DIC message every couple of weeks . No particular weather of temp. Although I never have driven in the rain. Oh BTW, do you have a pinging during hard acceleration? That disappeared after the PCM upload...GeorgeC :)
Old Apr 24, 2002 | 08:25 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
There is an ABS updated recalibration on 2001-02 for a false code 1288,and it is addressed in a TSB. :yesnod:Like the PCM,the ABS can be reflashed on the 2001-02,and the reflash has nothing to do with a PCM update :nonod:
Head to the dealer :p:
To Service Active Handling message C1288
