Passenger Door wont lock?
Old Jun 25, 2011 | 02:30 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default Passenger Door wont lock?
Having trouble...when I hit the lock button from either door the passenger side will not lock. I just hear a click but nothing happens. If I manually lock it and hit unlock...that works fine. It is only doing it to the passenger side...any tips? Help? Not sure what part has gone bad. There is the whole brain assembly on the door and then there is the small motor assembly that has 2 harnesses going into it. It is on the inside of the door really close to the lock mechanism/latch.
Need some pointers.
Old Jun 25, 2011 | 07:18 PM
Nate B's Avatar
Nate B
Here you go
http://www.ronjpics.com/Corvettestuff.htm#DCM
http://forums.corvetteforum.com/c5-t...direction.html
Old Jun 25, 2011 | 10:14 PM
XtremeVette
Thanks Nate. I read both of the posts. Anybody have any directions as far as the procedure. Is there 4 pins or 5 that need to be desoldered/resoldered? I have never done this particular job before and don't want to mess up a $400 part. I plan on doing both the middle and bottom relay which should be the locking and unlocking. Is there any reason to do the top one?
Any tips kindly appreciated from someone that has done this themselves.
Old Jun 25, 2011 | 11:16 PM
feeder82's Avatar
feeder82
When I did it I took the relays I got from Digikey to a C.B . radio shop and had a tech there solder in the relays, they are experts at circuit board repairs.
Old Jun 26, 2011 | 08:44 AM
baxsom's Avatar
baxsom
Just bought another door control module for 60 bucks from vettenuts. well worth it.
Old Jun 26, 2011 | 05:43 PM
02koolC5's Avatar
02koolC5
There are 5 pins to desolder I got a desoldering iron at Radio Shack for 11 bucks it has a bulb on it for suction when solder get hot worked really well.... and not sure about the top and side relays ...I think they're for windows up and down? Also, I used the (Ron) how to as well great directions there, good luck you could PM me if you need help
To Passenger Door wont lock?
