CLB installed, still got stranded! '02Z Help!
Old Jun 27, 2011 | 07:01 PM
Blue Angel's Avatar
Blue Angel
Default CLB installed, still got stranded! '02Z Help!
I'm currently waiting for a tow truck...
Two years ago I had my column lock up; 2002 Z06. So I bought the K harness from GM, installed it, and everything has been fine ever since. I hooked the harness into the body wiring but did not hook the column lock solenoid up to the other end. Worked great until after work today.
Start the car after work and get the "pull key, 10 sec." message. I ignore it, pull out and the car immediately dies.
I've spent three hours searching, pulling fuses, disconnecting the K harness, reconnecting the column lock solenoid, disconnecting the battery, clearing codes... I've tried everythin I can think of, even disconnecting the VSD from the differential so the car can't tell it's moving (it still knows).
Can someone help me out here? Did the K harness go bad on me? Do I need to frog around with a relay by the fuse panel or something (lots of confusing info on that, but nothing seems to relate to an '02Z)???
Insight much appreciated!
Old Jun 27, 2011 | 07:04 PM
Blue Angel's Avatar
Blue Angel
Sorry for the spelling... VSD is supposed to be VSS (vehicle speed sensor). Damn touchscreen!
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Mine does it every now and then(4 times in four years). I just shake the crap out of the wheel and it goes away......
Old Jun 27, 2011 | 08:15 PM
sprayed1998's Avatar
sprayed1998
Shake wheel and keep trying, pull key, shake wheel for 15 seconds then reinsert key till it unlocks, it always works when my pos decides to pull some bs on me.
Old Jun 27, 2011 | 10:29 PM
Blue Angel's Avatar
Blue Angel
This is what my car did to me, but one time it didn't unlock after repeated shaking. I walked home and came back after reading that shaking works so well for so many people. It took over a minute of VERY agresive pounding to get the wheel to unlock... so I drove it home and installed the CLB K harness (I had it sitting there for months). As soon as the harness went in all was good until today.
Old Jun 27, 2011 | 10:46 PM
Blue Angel's Avatar
Blue Angel
Originally Posted by 8VETTE7
First a GM K Harness is not a CLB by any stretch of the imagination.
http://forums.corvetteforum.com/c5-t...8952427-a.html
You seemed to think so there! If that is not a CLB, what is? The kit pictured in post #2 is what I put into my car, minus the lock plate... I figured if the solenoid was never going to move again what was the point in replacing that plate?
I hooked the harness to the female connector that leads to the BCM and left the other end undone... worked flawlwssly until today.
Chances are very good that your battery is low. Car starts with as little as 12.2 volts but the column lock electronics in the BCM needs more than 12.5 volts. A good battery will have 12.7 to 12.9 or more volts measured with a DMM directly across the battery posts and the negative battery cable disconnected. If you have 12.5 or less measured as stated the column lock electronics are not going to function properly.
The charger is on the car as I type this. I plan to test the battery voltage with the battery charger still hooked up, it should be well over 12.5 if it's fully charged. With the charger hooked up and (hopefully) a voltage above 12.5 we'll see if that works... that will at least rule out faulty electronics. Good info, thanks.
Leave the GM K harness out of the wiring as they typically fry when the battery voltage goes low. Connect the lock motor male connector to the female connector under the bottom of the dash that goes to the BCM. Clear all codes and error messages from the DIC and try it again.
This would be putting the car back to the way it was when the column locked on me before! That's the whole reason I put the K in there in the first place... am I missng something? I don't want to eliminate one problem by replacing it with another.
Old Jun 27, 2011 | 10:49 PM
Blue Angel's Avatar
Blue Angel
Good luck with that!
Old Jun 28, 2011 | 12:05 AM
Blue Angel's Avatar
Blue Angel
You clearly don't understand how the system works though you profess to.
Clearly I don't that's why I'm here asking for help! Believe me, I appreciate it, I'm just trying to understand what's happenng in there and why.
I was obviously wrong on the CLB thing... I called up GM PartsHouse and asked them for a Column Lock Bypass and that's what I thought they sent me. What I got was the K harness, P/N 19244027. I pulled it apart just now and there is a Tyco relay in there that smells like it got a little hot - it's probably fried. This makes some sense based on what I've just learned by reading through some old threads on the topic.
Looks like I've got to figure out what to do next... wait for a CLB from a vendor in the US (I'm in Canada) or call GM and get their latest version of the K harness... apparently now P/N 19244028. I'll have to make some phone calls in the morning.
On the topic of hooking up the column lock solenoid again, all I meant to say was that the old solenoid is what caused all of this in the first place. Hooking it back up will put me at risk of a locked column just like before. Sorry if I sounded like I was trying to be stubborn, I'm just a bit frustrated with this whole thing... good thing the tow was covered under my Roadside Assistance!
And once again, THANK YOU for all of your input. I've helped lots of folks on here with things I know about, and I sure appreciate getting help when I'm dealing with something I'm not familiar with. It's what keeps these forums rolling!
Old Jun 28, 2011 | 12:22 AM
Jnape's Avatar
Jnape
If you get an aftermarket CLB, Remove your K harness as they don't play well together.
Old Jun 28, 2011 | 01:00 AM
Blue Angel's Avatar
Blue Angel
Well, just came in. Battery disconnected read 12.83V, connected the reading dropped to 12.75V. All codes cleared, original lock solenoid plugged in, turned the key, "Pull key...", pulled key and waited, tried again, "Service Column Lock".
Looks like my original column lock solenoid is completely unresponsive, it seems to act the same way as my "fried" 19244027 K harness.
Looking at the schematic for the Tyco relay in the K, if I had a replacement I could just solder a new one in there..............
To CLB installed, still got stranded! '02Z Help!
