Passenger power window
Old Jun 28, 2011 | 09:06 PM
Ranger24's Avatar
Ranger24
Default Passenger power window
Anyone know which fuse connects the passenger power window? It roll down and it was fine the other day. 2003 C5 coupe.
Ranger24's Avatar
Ranger24
Correction, won't roll down.
Old Jun 29, 2011 | 01:00 AM
byronhunter's Avatar
byronhunter
Will it roll up, if so, it's not the fuse. Door control module has a relay in it that causes the problem you have, also the motors give trouble. Do a search for WINDOW WILL NOT ROLL DOWN, and you will find info to help troubleshot the problem.
Old Jun 29, 2011 | 12:09 PM
Ranger24's Avatar
Ranger24
Figured it out. After looking up power windows I found a thread that mentioned beating on the door above the speaker while holding the button down on the passenger side with the key in the on position. I thought BS at first but tried it and bingo, it worked. Apparently the regulator is in that spot and hangs on occassion in the C5.
Old Jun 29, 2011 | 01:18 PM
GoBallsDeep!'s Avatar
GoBallsDeep!
^worked for me...3 years later. Im guessing lack of use from previous owner. I take my targa off and roll both windows down regularly
To Passenger power window
