AC Problem
Old Jun 29, 2011 | 04:34 PM
OutaCash's Avatar
OutaCash
Navigator
Default AC Problem
With the AC on, the driver's side varies between cool and cold. The passenger side is consistently cold. No codes. I think (but am not yet sure) that it improves as the engine heats up.
Ideas?
Old Jun 29, 2011 | 05:51 PM
OutaCash's Avatar
OutaCash
Navigator
I have been able to eliminate both engine temperature and length of time the AC is on as affecting the problem.
Old Jun 29, 2011 | 08:31 PM
OutaCash's Avatar
OutaCash
Navigator
I've pulled the dashboard and watched things as I changed the temperature setting. I am confident that the actuators and the vacuum devices are working properly.
Is there a damper down at the bottom that cannot be seen from above?
Anyone?
Old Jun 29, 2011 | 08:54 PM
Dream C5's Avatar
Dream C5
Low freon is a known culprit of cool to warm driver side air been there done that get a set of gauges and check low and high side levels
Old Jun 29, 2011 | 09:04 PM
LoneStarFRC's Avatar
LoneStarFRC
Also check your vacuum line under the battery to see if it's damaged, etc and that your getting plenty of vacuum on it. When idling, the engine makes plenty of vacuum but when accelerating it drops off. Maybe partially disconnected or pulled loose from the rear of the intake manifold? Won't hurt to check both places.
Old Jun 30, 2011 | 11:13 AM
OutaCash's Avatar
OutaCash
Navigator
Thanks to both of you. I'll check your suggestions.
To AC Problem
