Fog light issue
Old Jun 30, 2011 | 12:39 PM
oakvillec5's Avatar
oakvillec5
Default Fog light issue
Question;
1998 C5 vert, stock fog lights are not working, the light on the switch was working for months, it is now out when switched on, so neither is working now. Finally got at it this morning, assumed the fuse, however the fuse looks good, got another one at the dealer, still does not work, nor does the light on the switch. I know the stock fogs don't throw much light, I just want everything to be working. Assuming #6 fuse (10 amp) if I am reading the manual properly.
Any thoughts?
Thanks in advance
Old Jun 30, 2011 | 01:23 PM
byronhunter's Avatar
byronhunter
Old Jun 30, 2011 | 01:59 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Verify power out of micro relay 39.
If the relay is bad then you will not get a power light on your button inside the car as well as no lights.
Second thought is that the grounding of both fog lights is located at a small grounding block just above the pass wheel well (underhood)... just in front of the engine coolant tank. Take it apart and clean all the grounding connections.
Toque
Old Jun 30, 2011 | 02:06 PM
byronhunter
Check IP fuse #32, that ground would no cause the light on the switch to not come on!
Old Jul 1, 2011 | 12:01 AM
oakvillec5's Avatar
oakvillec5
Thanks, I will check in the AM and report back.
Old Jul 1, 2011 | 07:17 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Toque
My 98 fog lights sometimes would come on and other times they wouldn't. The instrument panel lights were doing the same thing. I cleaned the two grounds G101 & G102 that Toque referred to. They are located on the frame on the front inside corner of the windshield washer tank and the front inside corner of the coolant tank. They are black. Take them off and take them apart to clean.
Old Jul 1, 2011 | 07:27 PM
65GGvert's Avatar
65GGvert
If the light in the switch isn't coming on either, you may have a problem in the connector to the switch or it's disconnected.
Old Jul 1, 2011 | 07:51 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The fog lamp grounds are located together at the right forward frame rail
Old Jul 2, 2011 | 10:05 PM
Big Duk's Avatar
Big Duk
park lites only on?
Old Jul 2, 2011 | 11:25 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
My fog lights died last fall and I didn't worry about it until this spring.
Here's a very quick test that I used to discover my issue.
Step 1
  • Walk out to the car
  • Honk the horn
  • Assuming it works go to step 2
  • If it doesn't then you have more than one issue
Step 2
  • Open under hood fuse box and swap mini relay # 39 with mini relay # 36 (They're the same part number)
  • Honk the horn
  • If it works you'll have to keep digging
  • If the horn doesn't work then go pickup a new relay and you're done.
Worked for me.
Old Oct 3, 2019 | 04:46 PM
orvettevalley's Avatar
orvettevalley
1st Gear
I recently switch my original headlight to le mans. Now my fog lights don't work and the light on the switch doesn't work either.
Old Oct 6, 2019 | 10:47 AM
Deliso1's Avatar
Deliso1
Default Same problem
Had the same problem, I cleaned up the two grounds in the engine bay just behind the headlights and they started working again
To Fog light issue
