My column lock finally failed. I haven't decided yet whether it was good timing or not. Started backing out of my driveway and got the dreaded pull key message. So I got to drive my wife's Saturn Vue to work.
If anyone else is putting off the CLB - use me as an example not to.
Now I have to get one ordered and figure out how to get it unlocked.
Most clb's come with a harness that plugs into your cigarette lighter that will unlock the column (I know for sure the one from corvettes of houston does)... then you install the clb and you're troubles are over. You might want to find someone with HP tuners to reprogram the fuel shutoff to a much higher value than 2mph just to be safe...
First off I want to thank Corvettes of Houston for the incredible fast service - even over a holiday weekend. I ordered my CLB on Friday and it showed up on Tuesday.
The lock was stuck. I had to violently shake the steering wheel about 7 times - each time plugging the lighter adapter in to attempt retract the pin. On the 7th time I heard it pull back. I put in the CLB and everything was back to normal!
