CODE P0327HC Knock sensor?
Old Jul 5, 2011 | 03:28 PM
Speedway1's Avatar
Speedway1
Default CODE P0327HC Knock sensor?
Had a PCM 10 code PO327HC with check engine light on. Car does not run very well or wind up well with light on. Do I need just to change the Knock sensor? If so where is it located? And I assume the bad performance is due to this code.Right? thanks
Old Jul 5, 2011 | 03:37 PM
dougbfresh's Avatar
dougbfresh
There are 2 knock sensors UNDER the intake manifold.
Old Jul 5, 2011 | 05:57 PM
Speedway1's Avatar
Speedway1
wow 2? So I should change both??And the intake has to come off too.Anything easy anymore??
Old Jul 5, 2011 | 07:41 PM
lucky131969's Avatar
lucky131969
It doesn't get much easier. I guess you've never had to R&R a SBC intake.....much more work involved...
Old Jul 5, 2011 | 09:01 PM
Speedway1's Avatar
Speedway1
Actually Thats about all I have done.NEver been into an LS anything. It must be easy for them to put 2 sensors UNDER the intake manifold.lol
Old Jul 5, 2011 | 09:29 PM
lucky131969
Seriously, no manifold to seal up...no water leaks, vacuum, oil leaks to worry about. No dizzy to mess with. It's really quite easy.
To CODE P0327HC Knock sensor?
