Outside temp reads 29 when its 95
Old Jul 5, 2011 | 04:52 PM
Oldcharlie's Avatar
Oldcharlie
Default Outside temp reads 29 when its 95
Read several previous threads about outside temp sensor, all good.
Found sensor, unplugged sensor, found corroded pin, cleaned pin. Checked temp unplugged, 69 degrees.
Replugged old sensor, now temp reads 29. Unplugged old sensor, temp still reads 29.
Inspected wires with strong glasses, cannot see any issues.
Measured resistance across socket, 920k ohms, not infinite.
Gotta drive car, but with no ac, ouch! Help please,
Charlie
Old Jul 5, 2011 | 05:17 PM
dmarkshark's Avatar
dmarkshark
You did take the car out and drive it? THe temp will not change until you drive it a bit on the road.
Old Jul 5, 2011 | 05:42 PM
kingrobby25's Avatar
kingrobby25
Well, are you sure that where the car was parked it was actually 95˚F, because 85˚F is right around 29˚C. Maybe the temp display was changed to Celsius by mistake through the DTC.
Old Jul 5, 2011 | 06:00 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
That wouldn't be embarrasing at all..... Hope the fix is this easy!
Old Jul 5, 2011 | 07:45 PM
Oldcharlie's Avatar
Oldcharlie
Ah ha...the answer! Had NOT read this before.
Yes, took it out and drove it 3 or 4 miles, outside temp started moving up...and AC compressor came on.
Ordered a new probe...didn't want to try the old one again...even cleaned up.
Thanks too about C temp possilble change, but it was the driving that made it work. Interesting way the system "learns."
Y'll take care, Charlie
Old Jul 5, 2011 | 11:10 PM
Rickster1's Avatar
Rickster1
From: Longmont on the Front Range of Colorful Colorado
I am having the same problem since I did the resoldering of the hvac contriol unit in my '99 'vert. I am reading 32 F and 0 c so the ac will not kick in, I have driven the car for miles and the ambient temp does not change. I have cleaned the sensor connections.
Any other thoughts? I will put a new sensor in, but I hate to replace pieces without knowing they are bad. (sesnor is not expensive)
Thanks for any input.
Old Jul 6, 2011 | 02:56 PM
Oldcharlie's Avatar
Oldcharlie
Hi Rick,
Check the wires at the connectors. I had to put light there and use some + 2.0 glass to inspect clearly. Those gray wires with the black strip are separate by the blue snap on connector--which seems to be there to strengthen the connection. I would try unplugging the probe, drive it, and see if the outside temp goes to 69. The probe connects directly to the climate control module. In another thread on this, there is the electrical diagram. Also connector is copper, it could be corroded by water getting past the seal. I cleaned it all up, and even though my car has been in the rain twice, I guess ater gets in there even during washing. Keep us posted on how it goes. Cheers, Charlie--old electronics tech.
Old Jul 6, 2011 | 03:00 PM
Oldcharlie's Avatar
Oldcharlie
PS Check the resistance with the sensor unplugged. My car is the same year as yours...mine resistance between the pins was 920 K ohms. If you don't have a digitial volt ohm meter, Radio Shack has 'em for about $20...good investment for "digital cars" :-)
Old Jul 6, 2011 | 10:40 PM
Rickster1's Avatar
Rickster1
Charlie,
Thanks for the suggestions. I am on vacation and away from the car for a couple of days. I will give you suggestions a try. I fear I may have done some damage when I was touching up the solder joints in the control unit.
I'll let you know how it goes, thanks again for the input.
To Outside temp reads 29 when its 95
