Valve Stem Seals
Old Jul 5, 2011 | 05:55 PM
phil hunter's Avatar
phil hunter
Default Valve Stem Seals
I am going to be installing some Comp Cams 918 valve springs on my 2001 LS1 soon and want to replace the valve stem seals while I'm at it, since it makes sense to do so even though the motor has very low miles. I'm having difficulty figuring out what seals I need to buy. It seems that there are two different seals from the factory. The first design which is seal and separate shim and a second design which is a shim and seal in one unit. Apparently, the second design was used on 2002 and later LS1's.When looking at various aftermarket vendors, they don't seem to make this distinction. So my question; are these seals interchangeable? Which design is preferred?
Thanks,
Phil
Old Jul 5, 2011 | 05:57 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
Thanks,
Phil
Patriots valve stem seals all come with washers. I've swapped the seals twice on my car and used seals with washers both times. Call COMP and ask for what they use/recommend, because it could make a difference.
Old Jul 5, 2011 | 07:56 PM
crainholio's Avatar
crainholio
The later design 1-piece seal/seat pieces are easier to install, the earlier design 2-piece ones are easier to screw up.
If you go the 2-piece route invest in a proper seal driver, a socket will only booger up the seal and turn your engine into an oil drinker.
The only solid reason to go 2-piece is if you're using dual valve springs and need the extra inner-diameter clearance vs. 1-piece seal/seat units.
If you go with GM 1-piece seal/seats, they are different part#s for intake versus exhaust...and don't mix them up during installation.
Old Jul 5, 2011 | 08:06 PM
CamminC5's Avatar
CamminC5
Much better explanation....
Old Jul 5, 2011 | 08:36 PM
phil hunter
Thanks guys. i think I'll use the one piece seal, since the Comp Cams 918 spring is a direct replacement for the stock valve spring.
Phil
To Valve Stem Seals
