help with lowering the rear
Old Jul 6, 2011 | 09:51 AM
geogolf's Avatar
geogolf
Default help with lowering the rear
hope someone can tell me if when you lower the back of a c5 by just backing off the bolt that goes up through spring and not cutting the bushings, should there be a gap between top of spring and arm or should spring be tight against it. hope you know what I mean, there is about 1inch of bolt showing between top of spring and bottom of spindle arm
Old Jul 6, 2011 | 09:53 AM
4SFED Z's Avatar
4SFED Z
you will have a gap. no worries. be sure to leave at least two threads and give the car time to settle.
Old Jul 6, 2011 | 10:05 AM
geogolf's Avatar
geogolf
Default rear
nasty thanks for the reply there were 12 threads showing when I started now there are 5 left, just looks kinda funny with that gap between spring and arm so there is nothing to worry about right. ps thanks for the offer but will have to build up my funds before any more mods geo.
Old Jul 6, 2011 | 11:39 AM
4SFED Z's Avatar
4SFED Z
Be sure to let it settle and then measure by the rear jacking area, not the fenders.
To help with lowering the rear
