Check Engine Light & Code P0101 Mass Air Flow (MAF) Sensor Performance
Old Jul 6, 2011 | 11:03 PM
Johnny_B_Good's Avatar
Johnny_B_Good
St. Jude Donor '05 thru '26
Default Check Engine Light & Code P0101 Mass Air Flow (MAF) Sensor Performance
What needs to be done to correct this problem??? A couple of weeks back, the (stock) air filter was replaced with a Wix Air Filter....Could this be the cause of the check engine light and the code? Should I get a stock AC Delco to replace the Wiz? This is an '01 with an A4....68,XXX miles. Thanks for your replies.
Old Jul 6, 2011 | 11:56 PM
Jnape's Avatar
Jnape
Check for air leaks between the MAF and the throtle body. A loose clamp will alow air unmetered into the engine. This will throw a CEL as well as throw codes and run rough.
