Fuel Pressure issue
Old Jul 12, 2011 | 09:00 PM
Badd LS6's Avatar
Badd LS6
Default Fuel Pressure issue
i posted up this issue a lil while ago and since have just changed out the Fuel pressure sending unit for my pillar gauge..i turned the key to ON and the gauge read about 63..when i started it..it read back up to 75area..
i know the pressure is suppose to be at 59-60. so i talked to my friend that's a certified FORD mechanic and he asked if the fuel system is a return type system or a non-return type system and said if its non return the PCM may be commanding more fuel to compensate for the increased airflow which i have full exhaust and vararam intake with no tune cept a little tweak from a HPtuners.
said If its return style..maybe the regulator is blocking too much to return to the tank...i am unaware what style system this is.
any help would be great!
Old Jul 13, 2011 | 05:31 PM
Badd LS6's Avatar
Badd LS6
anyone?
Old Jul 13, 2011 | 08:22 PM
dougbfresh's Avatar
dougbfresh
What's the pressure at the Schraeder valve on a mechanical guage?
Old Jul 13, 2011 | 08:52 PM
lucky131969's Avatar
lucky131969
Old Jul 13, 2011 | 09:07 PM
Badd LS6's Avatar
Badd LS6
unfortunantly i do not have a mechanical gauge..where can i get my hands on one?
Old Jul 13, 2011 | 09:08 PM
dougbfresh's Avatar
dougbfresh
Originally Posted by Badd LS6
unfortunantly i do not have one..where can i get my hands on one?
Autozone, Sears, INTERNET!
Old Jul 13, 2011 | 09:33 PM
PEERPSI's Avatar
PEERPSI
The PCM turns the fuel pump off and on. It does not control the pressure by servo control of the motor. There is a regulator in the fuel pump itself in the tank. The reason systems have gone away from the return lines, as I understand it, is to prevent heating up the fuel. If you think about it pumping cool fuel up to the hot engine past the even hotter exhaust system and then dumping it back into the tank will raise the fuel temperature. Heat is not something you want to add to the fuel or air entering your engine. I expect evaporative emissions likely played a part in all this as well.
Ditto on measuring, on a temporary basis the fuel with a mechanical gauge. Maybe tape it to the bottom of the windshield and take a test drive. For no reason should it be brought into the passenger compartment. If you can't see/read it through the windshield you probably shouldn't be driving.
Old Jul 13, 2011 | 10:27 PM
Badd LS6's Avatar
Badd LS6
so do you think this can be a restrictive regulator issue? if indeed the fuel pressure is too high from the rail
Old Jul 13, 2011 | 10:53 PM
lucky131969
Why even speculate? Install a gauge at the rail, and troubleshoot!
Old Jul 14, 2011 | 01:14 AM
Badd LS6's Avatar
Badd LS6
well this is what my fuel rail looks like right now..it was a PITA! to replace that sender without it leaking..the easiest thing to get off is the FPSS,, so i'll go to autozone tomorrow and get a gauge.
it won't be like this for long, i'm gonna order the brackets that mount the solenoids on top of the intake manifold. pic was taken during installation, pardon the mess
Old Jul 14, 2011 | 02:00 AM
zeevette's Avatar
zeevette
Talk about over engineered!
Old Jul 14, 2011 | 06:02 AM
lucky131969
Yikes......what a mess. I hope you didn't pay someone to do that.....
Old Jul 14, 2011 | 06:09 AM
dougbfresh's Avatar
dougbfresh
Looks like he's on the "Spray".
Old Jul 14, 2011 | 12:01 PM
Badd LS6's Avatar
Badd LS6
sorry pic was taken during the nitrous installation, thats why it looks so messy..im ordering the brackets to mount the solenoids on top of the intake manifold.
To Fuel Pressure issue
