Oi cooler on C5 Z06 with a Procharger and Dewitts Radiator
Oil cooler on C5 Z06 with a Procharger and Dewitts Radiator
Has anyone successfully installed an oil cooler with a procharger kit on your car. There does not seem to be a lot of room in the front of the car. If you did install one or know someone who did, was there a lot of fabrication involved or is there a kit out there that will fit? Also has anyone instralled a screen mesh for the license plate? Did it help out a lot? It looks like it would. Is there a ready to install kit or is this something that you need to fabricate from your own plate cover? I am seeing some very high oil temps(265+) in 100+ deg weather.
However...265 oil is not bad on hot day. With a stock engine, folks have had them last for many many years with that as their max temp.
Some people cut out that area in the front and do that front screen mod, trim some bumper support/foam and put a cooler behind it.
I think someone did it in this thread.. I think
http://forums.corvetteforum.com/c5-g...car-today.html
I don't have the procharger kit, but I did mount my cooler behind the front plate like others have told you , if you look at the pics in the attached link you can see my oil lines in the space between the bumper and the splitter.
http://forums.corvetteforum.com/c5-g...-finished.html
GOTHAM VETTE that looks really good! That is exactly what i'd like to do if it is possible. Your oil temps must be pretty cool. I will send the shop one of your photos to see if they can do something similar. Thanks to everyone who replied. It is nice to know 265 isn't abnormally high during the summer. I just have never seen temps above 240 before and I have an LSX iron block motor which I think is culprit for the extra 25deg increase in oil temps.
