OK guys fuel pressure fix
Old Jul 13, 2011 | 11:01 AM
ssdungeon's Avatar
ssdungeon
Default OK guys fuel pressure fix
Every guage I put on the car goes crazy and stops working. Im done patching. The car is running fine and I assume the pressure is fine. Ill soon be installing the nitrous sooo...
A little history.
I did the DA thing of redoing my 97 fuel system like the 2001 models which I later found was WRONG.
I have aftermarket fuel rails and no regulator up top. I changed to a 2001 fuel pressure regulator/filter combo for the newer models.
I still have my return lines installed so now i am looking for the part numbers for what I need to order to basically plug and play with regulation back up top.
I have read that the aeromotive a1000 is the way to go.
Anyone with pics of a properly done setup and/or suggestions will be appreciated.
ssdungeon@hotmail.com
Ill need part numbers too.
This is for the 97-98 system.
Thanks,
