Window regulator pulley
Old Jul 13, 2011 | 05:19 PM
1slols1's Avatar
1slols1
Cruising
Default Window regulator pulley
Hey guys, a couple days ago my driver side window quit working on my '99 frc. I tried all of the solutions that I found searching on here and none of them worked. So I just pulled the door panel off today and was looking at it and noticed that one of the little pink pulleys was broken. I believe its the upper one towards the back of the door. Can I buy just this little pulley and replace it or am I going to have to replace the entire motor and regulator assembly just to fix this little part? Any help would be appreciated!
Old Jul 13, 2011 | 05:34 PM
Cratecruncher's Avatar
Cratecruncher
As often as the C5 regulators fail you can probably find another member to pull a piece off there old unit and mail it to you. Are you sure thats all that is wrong with it though? the pulleys usually don't break.
Old Jul 13, 2011 | 05:37 PM
1slols1's Avatar
1slols1
Cruising
That may not be the only thing wrong with it. I just gave it a quick once over and that was all I saw.
Old Jul 14, 2011 | 01:05 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I would think the motor would still turn although with a messed up pulley, things aren't going to work very well. The regulator is a full assembly. Wish I had known you needed one, as I tossed one out a couple of months ago when I replaced my driver's side. Sorry... Go to www.gmpartshouse.com for an OEM
Old Jul 14, 2011 | 02:34 PM
1slols1's Avatar
1slols1
Cruising
Haha thats about how my luck goes. I think I've decided to just replace the entire regulator and motor assembly just to be on the safe side. I found everything from Mid America Motorworks. Has anyone had any experience with them? I've never dealt with them before.
Old Jul 14, 2011 | 06:26 PM
dgrant3830's Avatar
dgrant3830
They are good to work with. Did you check Gene Culley at gmpartshouse.com? His price was pretty good but I didn't compare with Mamotorworks.
Old Jul 15, 2011 | 03:08 AM
Vette_Fan's Avatar
Vette_Fan
Well, I'm glad we got a thread going on the window issues.... Not to highjack...but to educate...
My Passenger side window stopped working a few months ago. It remained stopped for a few months. I could hear the click-click noise, like it wants to go down...but it wouldn't work. Then, one day, a friend just pushed on the window button (while we were driving) and it worked. And window was fixed for a while.
After a few months SAME problem. It's stuck again. Won't go down, but I can hear the click-click when trying to push the button down. I've used both side buttons...won't work. So, either I can wait for another "Lucky" day, when I might work (like before), or fix it somehow. Not sure what's the problem in this case...
Old Jul 15, 2011 | 05:49 PM
1slols1's Avatar
1slols1
Cruising
I checked on gmpartshouse.com but couldn't find the entire window motor/regulator assembly and now mamotorworks is sold out of the drivers side so I'll have to keep looking.
Old Jul 15, 2011 | 06:40 PM
dgrant3830's Avatar
dgrant3830
http://store.gmpartshouse.com/partlo...layCatalogid=0
Old Jul 16, 2011 | 12:54 AM
thetaxman's Avatar
thetaxman
flea bay
save some money
Old Jul 20, 2011 | 06:45 PM
Pie R Squared's Avatar
Pie R Squared
I just changed out my drivers side regulator and still have the old unit. Send me a PM if you still want the pulley.
Old Aug 5, 2011 | 07:03 PM
98TA86's Avatar
98TA86
I have the same problem but I haven't had a "lucky" day yet where it went down. Trying to figure out exactly what I need to replace before diving into buying parts. Also I've searched on here a little and tired some of the little tricks playing with the wires etc and nothing has made a difference
any ideas?
Old Aug 6, 2011 | 03:58 AM
kwik ws6's Avatar
kwik ws6
any ideas?
I have the same problem.
Old Aug 6, 2011 | 08:23 PM
98TA86's Avatar
98TA86
seems to be fairly common, should I just go ahead buy a regulator and motor or what???
Old Aug 6, 2011 | 11:55 PM
woodman300's Avatar
woodman300
St. Jude Donor '15
the window regulator is an assembly that consists of the motor and cables. it is a bolt in replacement. i found a video on the replacement of the c5 passenger side on you tube. if you search for it you should be able to do this. the job wasn't as easy as the guy in the video but it wasn't too hard either. just be careful removing parts. it is easy to break the switch panel and the reflector. the little plastic cover for the door screws is easy to break too. ask me how i know. good news is they are not expensive so i put in new ones. the switch panel was already broke and was not exactly cheap but o found a good used one.
the hardest part of the job is getting the window adjusted after putting in the regulator. there are adjustments for window alignment in three directions. up/down, front.back, and tilt in/out. also, the window itself can be placed in the clips that hold it and slid front to back. be sure you buy the gm part and mark the position of the window in the clip with masking tape or a sharpie. good luck
To Window regulator pulley
