Lost Instrument panel!
Old Jul 17, 2011 | 08:50 PM
yankees1's Avatar
yankees1
Default Lost Instrument panel!
Today our corvette club went on a road trip ! After we ate and started back ALL instrument panel gauges would not work! I turned the engine off and restarted the car but gauges would not work. We drove several miles and stopped at a produce stand and after re-starting the engine, all gauges worked again! It was very hot today which I thought might have an effect but this malfunction did not happen to any other vette. This vette is a 2003. Any ideas?
Old Jul 18, 2011 | 09:40 AM
yankees1's Avatar
yankees1
No one has experienced this??
Old Jul 18, 2011 | 12:31 PM
tesfrank's Avatar
tesfrank
This happened to me several times last year. I removed the dash to see if all wires were plugs properly and everythings looked fine. I replaced the alternator regulator and did not fix the issue. I did Bill Curley's ignition switch repair and nothing either.
This spring I looked at the acordeon wires in the driver's door and did not notice anything wrong. Though the gauges never went down since. I start to believe there was something wrong going on in those wires...
If it happens again, I would give it a try.
Old Jul 18, 2011 | 12:37 PM
DarkSpeed's Avatar
DarkSpeed
I was about to post a thread and saw this! I AM IN THE SAME BOAT
The one thing that works (believe it or not) is slamming your fist right above the gauge cluster....it resets itself...
BUT.....now after doing that for 2 weeks....the language has changed to computer code!!!
SOOO,,,,I'll be needing Bill Curlee or someone else on this forum with some know-how to help!
To Lost Instrument panel!
