Misfire code No spark from 4 coils in driver side
Old Jul 18, 2011 | 05:27 PM
Derek97C5's Avatar
Derek97C5
3rd Gear
Default Misfire code No spark from 4 coils in driver side
Hi, and thanks in advance for any help. I am new to this site and have a 1997. I now a little about auto mechanics but not sure about this. I drove the car got home parked it ,ran fine. Then about 2 hours later went to leave again just started it and it started missing very badly. I started pulling plug wires to see witch cylinder it was and all the passenger side seem to cause it to miss more when I pulled each of there wires then I started to pull each of the driver side and non of them made a difference and unlike the passenger side I got no spark from any of the coils. An engine code came up stating miss on cylinder 3, but like I said all driver side coils seem not to be putting out looked for damage on the wiring harness and saw none any suggestions?
Ok After further investigation I found that my No.1 injector fuse was blown problem solved.
Old Jul 19, 2011 | 08:08 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
There are the injector fuses to check...check all fuses just in case. Next, there is a ground wire connection where the coil packs ground together at the rear of the driver's side head...between the head and the firewall, on the head itself. Make sure its tight.
Old Jul 19, 2011 | 11:34 AM
Chevy Guy's Avatar
Chevy Guy
Check the fuel injector fuses as well.
To Misfire code No spark from 4 coils in driver side
