Need Torque Spec. Please Help!
Old Jul 21, 2011 | 06:18 PM
yellowLPEZO6's Avatar
yellowLPEZO6
Default Need Torque Spec. Please Help!
Would one of you ZO6 owners that has a GM service manuel, please check for me on what the torque spec. is for the REAR LOWER CONTROL ARM CAM BOLT NUT that is used to adjust WHEEL CAMBER.
This would be the bolt TO THE FRONT of the LOWER CONTROL ARM that is closest to the driver, that has the eccentric cam on both ends.
Thank You SO MUCH in advance for your help.
yellowlpezo6
dwparrish2003@yahoo.com
Old Jul 21, 2011 | 07:16 PM
GEMcLean's Avatar
GEMcLean
Lower Control Arm (Front) Cam Bolt Nut = 107 lb ft
Lower Control Arm (Rear) Cam Bolt Nut = 70 lb ft
