throwout bearing rattle fix?
Old Apr 18, 2022 | 01:23 PM
  #41
Jaysvette07's Avatar
Jaysvette07
Originally Posted by Eric D
The issue is when the clutch is out in neutral, the propshaft is spinning. This is what needs to be avoided. It's hard on the propshaft assembly. It can cause premature failure of the flex couplings.
So ive been doing it wrong this whole time?? i always turn my car off in neutral for the past 4 years. should i change it up now? im getting this similar noise when going into first, sometimes reverse. Also, when im in 3rd or 4th gear and i accelerate fast, at the start of the acceleration i can hear a slight gear grind. but it only happens at acceleration.
