just replaced the rear rotors on my 02 Z. the right side was hard to install, so i kind of forced it in but then, the rotor got stuck to the parking brake pads and the car won't move....
I tried removing the rotor but it's stuck to one of the pads and won't come out or even rotate.
Any ideas as how I can remove it without damaging it? the parking brake is off and it's disconnected from the back end.
Any advice would be appreciated!
Any luck on this? this sounds like an issue I might be having. My left rear brake wore prematurly so I proceded to replace my rotors/pads, but I can't seem to get the left rear rotor off. So I am wondering if I am something like this. I have no idea how the parking brake/brakes work together, but I guess it seems like there is a "grove" for it, and it might be stuck on there.
I , pretty much , had to hammer the rear rotor out. I had to use a lot of force to do so. Talking to people, it seems like a common problem with E-brake getting stuck to the rotor.
Since you're replacing the rotor anyways, I suggest doing the same thing but there is a chance that you might damage the E-brake shoe if you try to pry it out using a flat head screw driver. But , when installing the new one, I suggest loosing the E-brake spring a bit through a retainer ( something I didn't do) till you can slip the rotor in. You can see the spring once you remove the rotor.
Here is a link explaining how to loosen that spring :
I hope that was helpful and good luck.
Best Regards, Elie
Yes TY, I guess I will just get a BFH and try harder! and deff loosen them up before putting the new rotor on. The other side came on/off easy and what's wierd is the rotors were just replaced a year ago.
Adjust tje starwheel so there is just a slight drag when installing the rotor
If you had to force the rotor on the starwheel was out too far and the parking brake shoe (GM doesn't call it an emergency brake) will jam against the inside of the rotor. Too loose and no parking brake. Do it a few clicks at a time and once you get the darn thing off try again.
After beating the holy bejesus out of it with a BFH and getting the old rotor off, the new one went on no problem....... so I guess it just rusted on there a bit.
