Seat track removal
Old Jul 25, 2011 | 05:28 PM
c599vette's Avatar
c599vette
Default Seat track removal
Has anyone seperated the seat track from the saet. I need to replace two plastic pieces on the track assembly. Do I need to remove the leathe and cushoin.
Old Jul 25, 2011 | 05:49 PM
bumble-z's Avatar
bumble-z
I'm assuming you have the seat out of the car.
Set up side down on the work bench.
No you do not need to remove the leather or cushions.
Use a racheting box wrench up under the foam to unloosen the bolts
from the seat frame to track rail.
I removed mine over the winter to go from electric track/rails to
manual track/rails.
Good luck.
Old Jul 26, 2011 | 12:07 AM
NealB's Avatar
NealB
you do not need to take the seat off the tracks to replace the worn pieces in the seat fore/aft mechanism
lots of "how-tos" posted on the forum
PM me an email addy that will accept docs and I'll send you the write up I followed posted by another member
not difficult at all
Old Jul 26, 2011 | 02:53 AM
AsphaltGator's Avatar
AsphaltGator
I replaced the seat track in my 99 coupe last month and yes I removed the leather and cusion to get to the nuts holding the track to the seat frame.
Old Jul 26, 2011 | 06:48 AM
baxsom's Avatar
baxsom
are you just replacing the worn out rubber pieces that cause the seat to rock back and forth? There are 3 torx screws on the seat track itself that hold it together. one on the top back of the track and two smaller ones on the bottom just did mine last week. took 30 mins per seat.
Old Jul 26, 2011 | 03:34 PM
c599vette's Avatar
c599vette
The seat is out of the car and placed upside down. It seems to be impossible to get to the bolts holding the track to the seat. I need to replace the two rear Plastic rectangular pieces that hold the rear shaft to the track assembly. They broke and the seat dropped to the floor.
Old Jul 26, 2011 | 04:57 PM
NealB's Avatar
NealB
you have to move the seat as much UP as it will go before disconnecting power
that gives you room to get an open end wrench on all the nuts on the studs
Old Jul 26, 2011 | 05:22 PM
c599vette's Avatar
c599vette
Old Jul 26, 2011 | 09:24 PM
c599vette's Avatar
c599vette
Ok, I now have the track seperated from the seat. Not to hard. Who sells replacement parts for these tracks. I need the two ears that attach the rear shaft too the track.
To Seat track removal
