Gas and Break Pedals
Old Apr 27, 2002 | 01:12 AM
Hex29A's Avatar
Hex29A
Default Gas and Break Pedals
About a year ago, I noticed that the break and gas pedals of my 2000 A4 Coupe were not at the same height. The gas pedal was lower than the break, about a ¼ inch. I am absolutely sure that when I got the car, brand new, the two pedals were at the same height.
I asked the forum and I was informed that there is no “height adjustment” for the break pedal.
The height difference has now increased to about ¾ to an inch. The only way to describe it is as follows: With the car in Drive and without touching the gas pedal on a flat road, if I press the breaks just enough to keep the car from rolling, the two pedals are at the same height. Unfortunately I didn’t measure the distance of each pedal from the floor so I can’t tell if the break pedal is “rising” or the gas pedal is “sinking”.
Is this “problem” unique to my car? Can someone “guess” the cause of this? Is something “broken/installed incorrectly”?
My brakes are not spongy and the car stops with ease after a ¼ mile run at 110 MPH. You help is appreciated.
[Modified by Hex29A, 12:13 AM 4/27/2002]
Old Apr 27, 2002 | 02:12 AM
LTD's Avatar
LTD
Default Re: Gas and Break Pedals (Hex29A)
just so that i (we) understand your question, your brake pedal relative to your gas pedal is much higher by 1/2 inch for no apparent reason?
Old Apr 27, 2002 | 02:40 AM
Hex29A's Avatar
Hex29A
Default Re: Gas and Break Pedals (LTD)
Correct
To Gas and Break Pedals
