Two Piece Rotors????
Old Apr 27, 2002 | 10:46 AM
AFVETTE's Avatar
AFVETTE
Default Two Piece Rotors????
Just what is meant by a "two piece rotor" vs a single piece rotor? What is the difference/value etc of this design? Any down sides?
Tom
Old Apr 27, 2002 | 11:26 AM
Venger's Avatar
Venger
Default Re: Two Piece Rotors???? (AFVETTE)
A two piece rotor has a lightweight central hub that mounts to a donut shaped outer rotor. There are pictures at several sites - Baer for example.
The advantage is that the center hub piece is usually very light, and usually does not need to be replaced, just the outer friction surface of the rotor. Something like 8 pounds less weight per rotor. And considering you are likely increasing the rotor size at the same time, you get better braking and lighter weight.
Of course, you are already familiar with a single piece rotor, which comes on nearly every car made - the whole hub, the mount and the friction surface, is cast in one piece...
Venger
Old Apr 27, 2002 | 01:56 PM
NEED FOR SPEED's Avatar
NEED FOR SPEED
CI 3-4-5-6-7-8-9-10 Vet
St. Jude Donor '07
Default Re: Two Piece Rotors???? (Venger)
Baer Eradispeeds for the front are 2 piece! Should be able to find a lot of pictures.
Old Apr 28, 2002 | 01:18 AM
Bill Reid's Avatar
Bill Reid
Default Re: Two Piece Rotors???? (NEED FOR SPEED)
Here's a pic of a front C5 Baer Eradispeed with Z06 calipers on my 85 :)
Old Apr 29, 2002 | 06:15 AM
C5 Frederik's Avatar
C5 Frederik
If you want to use ie. ceramic rotors, they must be in two pieces. The hub is made of aluminum.
Frederik
Old Apr 29, 2002 | 08:56 AM
AFVETTE's Avatar
AFVETTE
That's what I thought. I'm waiting for Shawn @ LAPD to ship my EradiSpeed Enhanced rotor's but noticed they also sell the "two piece" rotors. I couldn't figure out what the two parts were that made up the rotors.
Great info here - thanks.
Tom
USAF Retired
Old Apr 29, 2002 | 10:49 AM
Venger's Avatar
Venger
When my rotors go, or when I have more money than sense, I'm going to replace them with some two piece rotors - I like the larger size with reduced weight. Better braking, lower weight - can't be beat.
Venger
P.S. And with the stock C5 wheels, they look extremely choice...
To Two Piece Rotors????
