Aftermarket Rim Offset Question
Old Jul 29, 2011 | 11:34 AM
zavod's Avatar
zavod
Default Aftermarket Rim Offset Question
I am looking at a set of rims for my 98 C5 Vert.
Will these fit on my car without spacers or rubbing issues?
19" X 9" with a 50MM OFFSET
20" X 10.5" with a 65MM OFFSET
Thanks,
Old Jul 29, 2011 | 03:20 PM
zavod's Avatar
zavod
Nobody? Anyone got any ideas on who to ask? Ive searched but could find a good straight answer.
Old Aug 1, 2011 | 05:13 PM
yyzmsp's Avatar
yyzmsp
From: maple grove and North Port fl mn and now florida
It is not a simply answer to your question as you have not included the size/heights of your new tires. ie the front rims you are talking about are 19", I presently have 18" with a 9" wideth on the front which is a half inch wider but with a diff offset but close to yours. My tires are stock C5 sizes, but just barely clear the inner fender wells as they stick out around 10 mm more than stock. A higher tire would def scrub. The rears dont seem to be as big an issue as you are near stock wideth and offset and there is a little more room, but again we need to know the tires you plan on running.
Not trying to give you a hard time but it is a little more complicated than it appears as all the offset measurements are based on centerline of the wheel and when you start widening the wheels that throws all the offset comparisons off, then there is the tire height.
Give me some more info and i will see what i can do. I maybe a few days getting back to you as I am an Airline pilot and travel all over the world and sometimes dont have a chance to check the forum....cheers Rick
Old Aug 1, 2011 | 10:57 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Thanks,
Stock is 58 mm and 65 mm
http://www.autolounge.net/calculators/tirespacing.html
Old Aug 1, 2011 | 11:20 PM
zavod's Avatar
zavod
The tire sizes are 265/30R19 and 285/30R20.
To Aftermarket Rim Offset Question
